[quote name='malcolm2' date='Sep 22 2014, 02:56 PM' post='2089046']
[quote name='barefoot' post='2088826' date='Sep 21 2014, 07:58 PM']
there are 6 tabs with 2 spot welds each if you can pinpoint them and drill them out.
I had to replace the rear trunk panel, so cut around the 6 tabs and liberated the heat shield, then attached to the new trunk panel with SS pop rivets.
[/quote]
Rivets sound good. If you ever had to take it out, just drill them out. I took the "out of site" road. Stuck my wire brush in as far as I could reach, hit it with some primer and paint and called it DONE. On this piece there is nowhere for the water to sit and rust it out. The rust comes from the trunk acting like a dog bowl with water in it.
I am a fan of the spot weld cutter mounted in a drill. All the metal is still there. When you go to put it back, just tack the old spot to the old hole.
Here is photo of old trunk panel. you can see where i cut around the 6 tabs, this should get you close.
Barefoot
