Por 15 |
Por 15 |
partwerks |
Sep 24 2014, 08:24 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
What would be the best combo to use on the floor pans, once the floor tar is off? I have solid pans, so only anticipating surface rust.
http://www.amazon.com/POR-15-45008-Gloss-b...#productDetails For the center tunnel, or can/should the tunnel be taken off to remove the rust? http://detaildoctor.com/internal-frame-coa...-wspray-nozzle/ |
dan_the _body_guy |
Sep 25 2014, 11:25 AM
Newbie Group: Members Posts: 28 Joined: 1-April 14 From: cleveland ohio Member No.: 17,185 Region Association: None |
the key to por15 is its supposed to be applied directly over any rust its intended as a rust converter, it has very little uv protection so it breaks down in sunlight and must be top coated with another paint or in your case carpet. its a good product if used as intended. you do not want to apply it to clean metal or it will just peel off as it needs the rust to bond it if you have clean bare metal you would want to epoxy the area and use something else as a topcoat
SirAndy |
Sep 25 2014, 05:21 PM
Resident German Group: Admin Posts: 41,682 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
the key to por15 is its supposed to be applied directly over any rust its intended as a rust converter Doesn't work. Tried it several times ... (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 12th June 2024 - 09:33 PM |
