Found a better way to tie my car down on the trailer, Thought I'd share |
JStroud |
Sep 26 2014, 07:32 PM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
When my car broke down at parade I had AAA tow it home, the tow truck had these straps he used with a normal ratchet strap tie down that turned it into a wheel tie down.
When I got home I searched for the straps, the driver didn't speak very good English, if your thinking... Why didn't he just ask the tow truck driver....couldn't find them. Finally talked to a guy who owns a tow company.....found the straps. They are axle straps with loop ends, the with loop ends was the hard part, most are made with metal D ring ends, with the soft loop ends they won't damage your rims. You just thread the ratchet strap end through one loop end then put it behind the tire then back through the other loop end, then hook each end and tighten, clamps around the tire....no more crawling under the car....no more cutting straps going through the wheels. Makes me want to trailer my car somewhere. (IMG:style_emoticons/default/shades.gif) Now I just need to weld a few D rings on the trailer. (IMG:style_emoticons/default/welcome.png) |
stugray |
Sep 27 2014, 11:21 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE They are axle straps with loop ends, WHere did you get them? I planned on buying the tie downs that go on the shock mount bolt, but this looks good too. |
JStroud |
Sep 27 2014, 12:21 PM
QUOTE They are axle straps with loop ends, WHere did you get them? I planned on buying the tie downs that go on the shock mount bolt, but this looks good too. Try This They do offer a less expensive version for around $8.99 ea, the heavier duty $13.99 Ea I went with these rather than the tire tie downs because I use my trailer to haul other things besides cars, so I already have a lot of 2" ratchet straps, these just add to them, and were cheaper than the tire hold downs. Plus I figured I'd probably come up with other ways to use these. I'm not trying to persuade anyone from changing what they like.....just sharing what I found that works well for my situation.....take from it what you will. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 08:13 PM |
