Fog lights not working, calling all electricians |
malcolm2 |
Sep 28 2014, 02:26 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
OK, I know enough about elec. to test a few things so here is what I found once home from Okteenerfest.
Fog lights, driving lights, whatever you want to call them just quit working. The pull knob lights up I get 12v in the front trunk at the connection from the main harness. (that is with the connection separated) {with all wire connected, I get no reading} Grounds have continuity there too. I did not get 12 volts once I took the light apart, not the bulb holder, just the light was apart and I used an alligator clip to ground it. No volts. If I remove the alligator clip from the hanging light in the picture below and put the red lead of the VM on the white/ylw wire at the bulb holder THEN the black lead of the VM to a bolt on the car..... I get 12 volts. So with the bulb holder or the complete fixture assembled and grounded I get nothing. What is going wrong here? |
messix |
Sep 28 2014, 02:39 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
is there continuity on the ground of the socket [outer part the bulb fits into] to the ground on the car?
so if you have the light dismounted from the car and you run leads from light mount to car for you get 12V? if no, check for continuity from socket to mount of light with ohm function on meter [it should read just like if you touch the meter leads together] ? if no continuity look for why. broken wire? corrosion? |
Lo-Fi Version | Time is now: 7th June 2024 - 06:57 PM |
