Fog lights not working, calling all electricians |
malcolm2 |
Sep 28 2014, 02:26 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
OK, I know enough about elec. to test a few things so here is what I found once home from Okteenerfest.
Fog lights, driving lights, whatever you want to call them just quit working. The pull knob lights up I get 12v in the front trunk at the connection from the main harness. (that is with the connection separated) {with all wire connected, I get no reading} Grounds have continuity there too. I did not get 12 volts once I took the light apart, not the bulb holder, just the light was apart and I used an alligator clip to ground it. No volts. If I remove the alligator clip from the hanging light in the picture below and put the red lead of the VM on the white/ylw wire at the bulb holder THEN the black lead of the VM to a bolt on the car..... I get 12 volts. So with the bulb holder or the complete fixture assembled and grounded I get nothing. What is going wrong here? |
Mike Bellis |
Sep 28 2014, 04:53 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
If you have 12V to the light, the problem is with the light or a connection, most likely ground. In fact, try a new lamp. On very rare occasions, they can be bad, have continuity and not light up.
malcolm2 |
Sep 28 2014, 05:00 PM
If you have 12V to the light, the problem is with the light or a connection, most likely ground. In fact, try a new lamp. On very rare occasions, they can be bad, have continuity and not light up. It lit up with test wires directly to the correct places on the bulb. Both lights, right and left are out. I have pulled my elec. drawing from Prospero's garage and it does not have driving/fog lights on it. I see no white/yellow wires on this whole drawing. |
Lo-Fi Version | Time is now: 7th June 2024 - 11:05 AM |
