1975 914 1.8, Driving Lights Problem |
Ron Domkowski |
Sep 27 2014, 01:55 PM
Newbie Group: Members Posts: 5 Joined: 17-September 14 From: Illinois Member No.: 17,913 Region Association: Upper MidWest |
I am trying to figure out why my driving lights don't work. Can anyone tell me where the driving lights relay is located? In the front trunk or under the dash?
Thanks for your help Ron |
Ron Domkowski |
Sep 29 2014, 04:39 PM
I WAS EXCITED WHEN I PUT THE LOW BEAM HEADLIGHTS ON AND PULLED THE FOG LIGHT SWITCH WHICH LIT UP!! BUT THE TWO FOG LIGHTS DID NOT LIGHT UP. I MADE SURE THE HIGH BEAMS WERE NOT ON.
I RAN A HOT WIRE FROM THE BATTERY DIRECTLY TO THE HOT WIRE IN THE FRONT TRUNK THAT FEEDS THE TWO FOG LIGHTS AND THEY LIT UP. COULD IT BE A FAULTY FOG LIGHT RELAY ON THE FUSE PANEL? I ASSUME IT IS A VERY COMPLICATED RELAY AND VERY EXPENSIVE TO REPLACE. HOW CAN I TEST IT AND WHERE CAN I BUY ONE? THANKS, RON |
messix |
Sep 29 2014, 06:09 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
I WAS EXCITED WHEN I PUT THE LOW BEAM HEADLIGHTS ON AND PULLED THE FOG LIGHT SWITCH WHICH LIT UP!! BUT THE TWO FOG LIGHTS DID NOT LIGHT UP. I MADE SURE THE HIGH BEAMS WERE NOT ON. I RAN A HOT WIRE FROM THE BATTERY DIRECTLY TO THE HOT WIRE IN THE FRONT TRUNK THAT FEEDS THE TWO FOG LIGHTS AND THEY LIT UP. COULD IT BE A FAULTY FOG LIGHT RELAY ON THE FUSE PANEL? I ASSUME IT IS A VERY COMPLICATED RELAY AND VERY EXPENSIVE TO REPLACE. HOW CAN I TEST IT AND WHERE CAN I BUY ONE? THANKS, RON just swap it temporally with one of the others. and check fuse 10 |
Lo-Fi Version | Time is now: 7th June 2024 - 01:52 PM |
