gas tanked can not be coated?, the radiator shop said the gas tank can't be coated |
buck toenges |
Sep 30 2014, 11:28 AM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
The radiator shop just called and said they couldn't coat the inside of the gas tank because of a pan that is inside the tank. They said they couldn't get to the rust on the bottom of the tank and thus can't coat the inside. I assume you can coat the inside of the tank. help.
Old Yella |
Sep 30 2014, 01:42 PM
Old Yella Group: Members Posts: 158 Joined: 2-July 13 From: Canberra Australia Member No.: 16,086 Region Association: Southwest Region |
That's BS, I did mine with the por 15 kit. It took a few days. After using the marine clean and then the prep and ready it was perfectly clean. The only issue I had was the por 15 coating comes in a small can and I had to turn the tank for about an hour to get it all coated.
http://forums.pelicanparts.com/porsche-914...14-club-10.html The radiator shop just called and said they couldn't coat the inside of the gas tank because of a pan that is inside the tank. They said they couldn't get to the rust on the bottom of the tank and thus can't coat the inside. I assume you can coat the inside of the tank. help. |
Lo-Fi Version | Time is now: 11th June 2024 - 02:12 PM |
