That's BS, I did mine with the por 15 kit. It took a few days. After using the marine clean and then the prep and ready it was perfectly clean. The only issue I had was the por 15 coating comes in a small can and I had to turn the tank for about an hour to get it all coated.
http://forums.pelicanparts.com/porsche-914...14-club-10.htmlQUOTE(buck toenges @ Sep 30 2014, 10:28 AM)
The radiator shop just called and said they couldn't coat the inside of the gas tank because of a pan that is inside the tank. They said they couldn't get to the rust on the bottom of the tank and thus can't coat the inside. I assume you can coat the inside of the tank. help.
