gas tanked can not be coated?, the radiator shop said the gas tank can't be coated |
buck toenges |
Sep 30 2014, 11:28 AM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
The radiator shop just called and said they couldn't coat the inside of the gas tank because of a pan that is inside the tank. They said they couldn't get to the rust on the bottom of the tank and thus can't coat the inside. I assume you can coat the inside of the tank. help.
naro914 |
Sep 30 2014, 01:41 PM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
I've had two tanks coated... but mine were fairly rust free.
Old Yella |
Sep 30 2014, 01:42 PM
Old Yella Group: Members Posts: 158 Joined: 2-July 13 From: Canberra Australia Member No.: 16,086 Region Association: Southwest Region |
That's BS, I did mine with the por 15 kit. It took a few days. After using the marine clean and then the prep and ready it was perfectly clean. The only issue I had was the por 15 coating comes in a small can and I had to turn the tank for about an hour to get it all coated.
http://forums.pelicanparts.com/porsche-914...14-club-10.html The radiator shop just called and said they couldn't coat the inside of the gas tank because of a pan that is inside the tank. They said they couldn't get to the rust on the bottom of the tank and thus can't coat the inside. I assume you can coat the inside of the tank. help. |
ConeDodger |
Sep 30 2014, 02:07 PM
Apex killer! Group: Members Posts: 23,579 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I don't think there is a pan inside. There is a cylinder at the outlet to keep the gas from sloshing away in a corner and causing starvation.
I used the POR15 kit and got very good results. Looked very rusty when I started and like clean virgin metal when I got to the coating step. |
BeatNavy |
Sep 30 2014, 02:12 PM
I don't think there is a pan inside. There is a cylinder at the outlet to keep the gas from sloshing away in a corner and causing starvation. I used the POR15 kit and got very good results. Looked very rusty when I started and like clean virgin metal when I got to the coating step. (IMG:style_emoticons/default/agree.gif) I also used POR15. Came out great. Here's the after. The before will frighten you and should not be shown in polite company. The cylinder is visible in this shot. |
Jeffs9146 |
Sep 30 2014, 03:12 PM
You can also use a reverse zinc plate methode to electricly remove the rust.
Electrolysis to clean a fuel tank |
rick 918-S |
Hey nice rack! -Celette Group: Members Posts: 20,443 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I did the washing soda and battery charger method to clean mine. Worked awesome! No coating needed.
AvalonFal |
Sep 30 2014, 03:33 PM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
Here's my before and during cleaning (Marine clean, wire bush and rattling some nuts and screws inside for a while). Been over 3 years and no leaks or fuel problems.
bdstone914 |
Sep 30 2014, 04:41 PM
bdstone914 Group: Members Posts: 4,516 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
There is a divider baffle at least on the layer tanks with the plastic expansion tank. Might make cleaning more difficult.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 8th May 2024 - 09:03 AM |
