Hell hole repair, Recommendation |
watsonrx13 |
Aug 18 2004, 05:52 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Well, worked on the passenger's side of the engine compartment today. I removed the battery tray and started cleaning the hell hole. There's only a few small holes in the side wall and one small hole in the firewall.
Question: Should I cut out the side wall and replace with a patch panel, butt-welded or try to weld up the holes? BTW, the white showing through is a piece of paper taped on the back side so the holes would show up easier. Attached image(s) |
watsonrx13 |
Aug 22 2004, 12:02 PM
BTW, yes it is a PITA to get down there and attempt to weld, then attempt to grind the welds.
This is a shot after I applied the 'All Metal' filler, later this week I'll sand it down then paint. Attached image(s) |
Lo-Fi Version | Time is now: 7th June 2024 - 08:16 AM |
