914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,180 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
I saw this in the flyer, so I checked it out at the store in San Antonio. It is well made and half way light weight. Extends to about 20" with about a 12x14" rubber coated platform. Upper level comes off if needed. It would be a pretty stable platform to work with for engine/trans removal with out having to balance the trans end while lowering jack. I am probably going to get one for me because I do most of my work alone. Price is $189 but with a 20% off coupon brings it down to $150
Attached thumbnail(s) ![]() |
jacksun |
Member ![]() ![]() Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest ![]() |
hi,
I bought two of the 3 ton low profile floor jacks from HF. also bought one of the furniture dollies . having two floor jacks made the engine removal easy, one would have been a hassel with constant moving of the jack from side to side as you lower and raise the car during engine removal/installation. the furniture dolly worked great for the process. easy to move the engine/trans around the garage. I do not have an engine stand, so I just used the dolly and the two floor jacks to elevate the engine/trans as high as the floor jacks would go, and then placed four jack stands under the dolly. worked for me. also.. I think that you can not use the 20% coupon on floor jacks. it is in the small print on the coupon. randal |
Lo-Fi Version | Time is now: 1st July 2025 - 04:53 PM |
