| McMark |
Oct 12 2014, 02:16 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
I've been collecting parts for my conversion and I just got my 911 ignition switch (P/N 911.613.011.01). It's got the correct silver center. I have an original 914/6 steering column, but the steering lock arm doesn't fit into the bracket into the column. I know this is a 'normal' thing and removing some material will make everything work fine. But since I'm mostly insane, I'd like to see pics of a real 914/6 ignition switch to compare and replicate if possible.
Anyone have pictures? Even better, anyone have one they can measure? And what about the original unit part number? What's that? The number in the PET doesn't seem to match the numbers I've seen. Attached image(s)
| sixnotfour |
Oct 12 2014, 07:17 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,029 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains
they added more material so the bolt actually secured the lock in position = hareder to remove... grind flat = done
| McMark |
Oct 12 2014, 09:34 PM
Awesome! Now I can make mine look right.
grind flat = done You make it sound so easy. If only it was for the obsessive compulsive. (IMG:style_emoticons/default/unsure.gif) |
McMark 914/6 Ignition Switch Oct 12 2014, 02:16 PM
SirAndy Yepp, i had to shave off some material from the 91... Oct 12 2014, 03:51 PM
SixerJ Hi Mark, does this help?
I bought a complete -6 l... Oct 12 2014, 03:56 PM
SixerJ Last 2 pictures, the last one was a bit difficult ... Oct 12 2014, 04:01 PM
McMark SixerJ, THANKS! Can you take one more with th... Oct 12 2014, 04:08 PM
SixerJ
SixerJ, THANKS! Can you take one more with t... Oct 12 2014, 04:23 PM
biosurfer1
grind flat, throw away, grind flat, throw away,... Oct 21 2014, 03:40 PM
914Sixer 914-6 PET shows the lock assembly as 911.613.901.0... Oct 12 2014, 09:24 PM
SixerJ Mark,
Apologies for hijacking your thread, but co... Oct 13 2014, 09:09 AM
larryM notwithstanding all the perfection above
- if yo... Oct 16 2014, 09:21 PM
McMark Pictures of the steering column. Let me know what... Oct 21 2014, 12:21 PM
Mark Henry This is a lot of work...wasn't the '72 six... Oct 21 2014, 01:01 PM
This is a lot of work...wasn't the '72 si... Oct 21 2014, 03:34 PM
altitude411 What is this connection for? My '70 six does ... Oct 21 2014, 04:32 PM
type47fan
What is this connection for? My '70 six does... Oct 21 2014, 07:28 PM
McMark
Also does any know of a clamshell vendor or have ... Oct 21 2014, 08:08 PM
altitude411 Ah, that makes sense. Good, I'm glad I don... Oct 21 2014, 07:54 PM
altitude411 Thanks for the heads up Mark, I'll keep shoppi... Oct 21 2014, 08:21 PM
SixerJ Thanks for the pictures, wow, even a NOS sticker, ... Oct 22 2014, 03:50 PM
SirAndy Presumably to make a 6 repro, you would start with... Oct 22 2014, 07:48 PM
SixerJ Great thread, thank you.
It's prompted me to ... Oct 24 2014, 01:16 PM
McMark Got my switch modified by the machine shop. They ... Nov 26 2014, 03:41 PM
SixerJ
Got my switch modified by the machine shop. They... Nov 28 2014, 11:48 AM
Harpo I have never been sucessful in rekeying a 911 igni... Nov 27 2014, 11:13 AM
John
I have never been sucessful in rekeying a 911 ign... Nov 30 2014, 08:19 PM
I have never been sucessful in rekeying a 911 ig... Nov 30 2014, 08:32 PM
John
[quote name='John' post='2116838' date='Nov 30 20... Dec 4 2014, 09:10 PM
jkb944t Would anyone know where a good place to start to l... Apr 15 2015, 10:35 AM
naro914 I went a different route for the column...I wanted... Apr 15 2015, 02:12 PM
jkb944t If I understand your post correctly you simply rem... Apr 15 2015, 02:47 PM
naro914
I’m not sure what part you were going to sell t... Apr 15 2015, 03:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th November 2025 - 08:44 AM |
