Downerman |
Member ![]() ![]() Group: Members Posts: 168 Joined: 23-April 09 From: Monterey County, California Member No.: 10,296 Region Association: None ![]() |
So, after restoring this 73 and having a blast with the Renegade aspect (love the way it drives).... I have a bit of a problem. Never paid any attention until I started to drive the car and getting this gas smell. Well it didn't take but 5 seconds once I actually looked at the line off the filler. The guy (PO) had just looped the line back through the 1/2" nipple into the fuel spill area. So, here's my question. What are you conversion guys doing/running on your rides. Are you using the stock overflow and charcoal unit with all the vacuum lines? Some modified versions?? Would love to know.
Attached is my current setup. I'm embarrassed that I never caught it. Oh, and for those who care to know, I replaced that old line and fitted a new line and bottle catch to see if that was my source of gas. It is..... Dave ![]() |
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,491 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
Later 75s & 76s have a more modern setup. That 1/8" hose goes to a big black plastic box that surrounds the filler. Then a 1/8" hose goes from that, to a tube with the fuel lines, to the intake. It's all vacuum.
Modern cars have a switch so it only flows during idle. The point is to capture the gas vapor so it doesn't enter the atmosphere. Run it to the carb, unless the manifold has a vacuum inlet. There should be no fluid, just vapor. I would think 40yo charcoal would no longer be activated, thus making it pointless to install. The 70s and 80s were a horrible time for emissions solutions. EDIT: 5v blower? |
Downerman |
Yeah 5V...... small, quiet, low CFM and it has a 100,000 hour failure rating at 20 degree's celsius. Shipped to the house it's $15.00 and would supply a nice moderate amount of air into the canister. Everything else I looked at would blow like a son of a gun.
Hey thanks everyone. I got all my parts in from Parts Heaven and just need to attach the line going to the air cleaner and of course mount the small blower up front. I'm convinced that this "Stock" setup (less the small blower) will work just fine. Dave Later 75s & 76s have a more modern setup. That 1/8" hose goes to a big black plastic box that surrounds the filler. Then a 1/8" hose goes from that, to a tube with the fuel lines, to the intake. It's all vacuum. Modern cars have a switch so it only flows during idle. The point is to capture the gas vapor so it doesn't enter the atmosphere. Run it to the carb, unless the manifold has a vacuum inlet. There should be no fluid, just vapor. I would think 40yo charcoal would no longer be activated, thus making it pointless to install. The 70s and 80s were a horrible time for emissions solutions. EDIT: 5v blower? |
Lo-Fi Version | Time is now: 11th July 2025 - 11:47 AM |
