> No overflow tank for fuel.
Downerman
post Oct 13 2014, 11:10 AM
So, after restoring this 73 and having a blast with the Renegade aspect (love the way it drives).... I have a bit of a problem. Never paid any attention until I started to drive the car and getting this gas smell. Well it didn't take but 5 seconds once I actually looked at the line off the filler. The guy (PO) had just looped the line back through the 1/2" nipple into the fuel spill area. So, here's my question. What are you conversion guys doing/running on your rides. Are you using the stock overflow and charcoal unit with all the vacuum lines? Some modified versions?? Would love to know.
Attached is my current setup. I'm embarrassed that I never caught it. Oh, and for those who care to know, I replaced that old line and fitted a new line and bottle catch to see if that was my source of gas. It is.....
Dave
skeates
post Oct 15 2014, 04:06 PM
Not sure that little guy will move enough air for you. It's spec'd for .57 CFM at .18" H20. Might be enough for a microchip in a laptop, but it's just gonna make noise in your car. Not sure exactly what kind of CFM you're going to need, but I'd shoot for something in the 2-5 CFM range. And 12 volts for sure.
Downerman
post Oct 15 2014, 06:34 PM
I know..... .57 was exactly (or near) what I was wanting because I don't think the original fan push was much either. I bet I don't even hear it. Yes, getting from 12V to 5V is super simple and yes I checked my favorite place (Digi-key) and no I did not like the 12V blowers I saw. To much flow, larger and I would bet noiser.
For the record, with everything in place except the tiny blower, I filled her up. Ran it through the tests... (Left turn sharp, left turn sweeper and hard aceleration and stops and guess what? Not one wiff of gasoline.
Man I don't get this 12V thing. taking a device that runs 4-5 volts from 12V is nothing more than a tiny voltage regulator. There's a zillion sizes, types and brands. Oh well, to each their own.
Dave
QUOTE(skeates @ Oct 15 2014, 03:06 PM) *
Downerman   No overflow tank for fuel.   Oct 13 2014, 11:10 AM
76-914   Run it on the outside after you remove the valance...   Oct 13 2014, 11:30 AM
Cap'n Krusty   Eliminating the charcoal evap unit results in gas ...   Oct 13 2014, 12:03 PM
Downerman   So, using the diagram below, I have no fan (Blow) ...   Oct 13 2014, 01:57 PM
Downerman   Wondering how important flow from the fan (Stock 9...   Oct 13 2014, 04:31 PM
boxsterfan   Eliminating the charcoal evap unit results in gas...   Oct 13 2014, 02:19 PM
Porsche930dude   i ran that small hose down under the tank and out ...   Oct 13 2014, 05:53 PM
Downerman   Trying to stay legal so to speak although that did...   Oct 13 2014, 06:23 PM
Dave_Darling   ... California was going to require smog on EVERYT...   Oct 13 2014, 10:49 PM
Downerman   I sure hope your right on this one. Dave ...   Oct 14 2014, 09:42 AM
Cap'n Krusty   You were lucky to get the Westy approved, because ...   Oct 13 2014, 06:39 PM
bulitt   I believe I read Sir Andy's fix in some thread...   Oct 14 2014, 10:50 AM
Downerman   Check this out..... found this Micro fan and has s...   Oct 14 2014, 01:38 PM
Chris914n6   Later 75s & 76s have a more modern setup. That...   Oct 14 2014, 02:07 PM
Downerman   Yeah 5V...... small, quiet, low CFM and it has a 1...   Oct 15 2014, 10:08 AM
r_towle   Run the little small vent line down the back and o...   Oct 14 2014, 07:38 PM
Chris914n6   I was questioning the 5 volts part. Nothing in the...   Oct 15 2014, 02:29 PM
skeates   Not sure that little guy will move enough air for ...   Oct 15 2014, 04:06 PM
Downerman   I know..... .57 was exactly (or near) what I was w...   Oct 15 2014, 06:34 PM
skeates   I know..... .57 was exactly (or near) what I was ...   Oct 15 2014, 06:58 PM
Downerman   You know this is why I hate email and sometimes po...   Oct 15 2014, 07:10 PM
skeates   I apologize for coming across that way but once a...   Oct 15 2014, 07:39 PM
r_towle   Too late, we all know you wear panties now.   Oct 15 2014, 07:30 PM
- Lo-Fi Version Time is now: 11th July 2025 - 12:10 PM
