> Newbie here - 1976 914, New owner of a 76' 914
Easyb
post Oct 15 2014, 08:31 PM
Hello. I just bought a 1976 914. First Porsche, first pre 80's car.
I'm very excited as have been looking forward to owning one for a while. The car isn't perfect so I'm gearing up to start restomoding it to be more practical and more reliable.
I don't know anything about the Porsche, having been a Bimmer guy up to now but I'm eager to learn.
Car needs an alternator and probably transmission rebuilt and some other electrical issues.
I'm in the Houston area, any one else around this neck of the wood?
thanks.
EasyB
Easyb
post Oct 19 2014, 01:47 PM
I plan on going through most of the car and prepare a list of what needs to be repaired.
What i've found so far:
- Alternator seems defective.
Current one was diagnosed dead (car died several times on the way from seller, drained batteries, performed test from Autozone type of store).
- A rubbing noise can be heard when the wheels are turning but a visual inspection to each wheel hasn't revealed anything - nothing seems to touch). The sound is metallic as if the brake shield was touching another part of the wheel.
- Electrical needs to be evaluated. Turn signals and rear lights not working.
- When driving the car, in 4th/5th gear, engine seems to sometimes "skip a bit" it acts as if it were going to stall but doesn't stall.
Still going through the car.
Any preferred recommendations on where to order parts from besides eBay, Pelican? Any other areas I should inspect and focus on?
Your thoughts????
barefoot
post Oct 19 2014, 06:00 PM
QUOTE(Easyb @ Oct 19 2014, 03:47 PM) *
Your thoughts????
Look at Auto Atlanta site, they have very helpful exploded parts diagrams for most everything. Click on one of the images and a P/L appears keyed to the item numbers in the diagrams. They tend to be pricey however.
For any rubber weatherstripping, 914 Rubber is where to go.
Barefoot
Easyb   Newbie here - 1976 914   Oct 15 2014, 08:31 PM
hndyhrr   :wttc: pic please, you've come to the righ...   Oct 15 2014, 08:38 PM
patssle   Another Houstonian! Welcome...there aren't...   Oct 15 2014, 08:46 PM
Easyb   Another Houstonian! Welcome...there aren...   Oct 15 2014, 10:34 PM
Easyb   Another Houstonian! Welcome...there aren...   Oct 16 2014, 07:12 PM
sb914   Hello. I just bought a 1976 914. First Porsche, f...   Oct 15 2014, 10:03 PM
Mike Bellis   :wttc:   Oct 15 2014, 10:05 PM
Gustl   :wttc: ... from far, far away :D   Oct 15 2014, 10:06 PM
Easyb   Thanks for the welcome. Car needs some work and I...   Oct 15 2014, 11:19 PM
Cuda911   Congrats on the new teener! Also, you don...   Oct 16 2014, 12:59 AM
Easyb   Congrats on the new teener! Also, you don...   Oct 16 2014, 11:38 AM
JawjaPorsche   Welcome to the Madness!   Oct 16 2014, 06:23 AM
SteveL   Welcome! This site of full of great people wh...   Oct 16 2014, 06:58 AM
Easyb   Some pictures of the car quickly taken via cell ph...   Oct 16 2014, 11:47 AM
mr2by4   Thank god you bought it before I did! How can ...   Oct 16 2014, 01:11 PM
green914   Looks like you got a good car to work with have fu...   Oct 16 2014, 01:35 PM
7TPorsh   1976? You sure? Older bumpers.   Oct 16 2014, 04:15 PM
pilothyer   :wttc: Looks to be pretty nice and for a 76 t...   Oct 16 2014, 04:35 PM
worn   Hello. I just bought a 1976 914. First Porsche, f...   Oct 16 2014, 07:40 PM
BobR   Welcome to the forum from another 1976 owner. Ther...   Oct 16 2014, 08:04 PM
BobR   This is a link to the first thing you will need fo...   Oct 16 2014, 08:09 PM
PanelBilly   emocleW   Oct 16 2014, 08:26 PM
Easyb   I plan on going through most of the car and prepar...   Oct 19 2014, 01:47 PM
barefoot   I plan on going through most of the car and prepa...   Oct 19 2014, 06:00 PM
Porky   - A rubbing noise can be heard when the wheels ar...   Oct 21 2014, 09:44 AM
Mikey914   Just a thought on the alternator. Do you have alt ...   Oct 19 2014, 07:53 PM
Easyb   Just a thought on the alternator. Do you have alt...   Oct 19 2014, 09:03 PM
rick 918-S   Full on brake job if the car has been sitting. :w...   Oct 19 2014, 08:11 PM
Easyb   Full on brake job if the car has been sitting. :...   Oct 19 2014, 09:05 PM
Bleyseng   Full on brake job if the car has been sitting. ...   Oct 23 2014, 07:48 AM
Beeliner   I was resigned to buying an alternator when my mec...   Oct 21 2014, 05:05 PM
rhodyguy   I think mark wants to know if the light is on when...   Oct 21 2014, 06:11 PM
malcolm2   I struggled a bit with the ALT. I ended up gettin...   Oct 21 2014, 07:46 PM
Easyb   Thanks a lot for all the replies. The alternator ...   Oct 22 2014, 09:36 PM
mdelwiche   :wttc: Welcome from another '76 owner. Just ...   Oct 22 2014, 10:59 PM
Easyb   Quick update: alternator problem solved, had to re...   Nov 18 2014, 12:01 AM
mdelwiche   Quick update: alternator problem solved, had to r...   Nov 18 2014, 12:13 AM
Easyb   Quick update: alternator problem solved, had to ...   Nov 20 2014, 09:13 PM
hndyhrr   [quote name='mdelwiche' post='2111756' date='Nov ...   Nov 20 2014, 09:43 PM
- Lo-Fi Version Time is now: 1st August 2025 - 08:45 AM
