> Type 4 Store 2270, Type 4 Store 2270
lexatola
post Oct 18 2014, 12:08 AM
I'm getting close to pulling the trigger on the 2270 engine kit from the Type 4 store. I'm curious if anyone knows what the difference between the kit and the Raby 2270 SR. I see they each have different HP specs. Do we think this is an actual difference or just a difference in written spec? Same cam? Same Heads? Curious if this kit can make better HP than 140? Headers? Other tested and ordained cam?
I'd appreciate any input based on experience,
Best,
Alex
Jake Raby
post Oct 20 2014, 08:47 AM
Engine Surgeon
QUOTE(lexatola @ Oct 17 2014, 10:08 PM) *
Best,
Alex
When I sold the Type 4 Store to LN I also sold them all the engine kit combinations and I reconfigured them to be easier to assemble and tune. This was done to aid Charles and the team in regard to supporting the kits.
None of the kits that are sold are configured the same as my turn key engines. I use different combinations and I custom build each engine. The 2270 SR is just a base combination, when I consult with a buyer I will generally alter the combination to better fit their operating environment, and application, as well as the cooling system being used, type of fuel thats available int he area and about 15 other variables that is found on my order spreadsheet, all of which can change cam, head and other sub- system requirements.
LN has done very well continuing what I started with the Type 4 Store, and taking it to the next level, that I had no desire to do. Getting rid of the burden of the store has freed up all my resources to be used for R&D and engine building, which is where my passions always have been. I took the area where the store used to be and added 4 more engine assembly stations and another clean room, which has helped us reduce delivery times from one year, down to around 5-6 months for turn key engines.
Now, I have fun again, without any retail purchasers.
I have an Emory 356 that puts out about 120hp at the wheels and weighs in at about 1600lbs.
Here's my Raby Typ456 Outlaw, built from a 64C. It makes 185 at the wheels and isn't conventional. Weighs around 1520 with lexan windows and most other lightweight goodies. It was a SCCA/VSCCA race car for 40 years and its just as light now, as it was then, maybe a little lighter since I pulled the cage out of it when akin it into my street car again.
KELTY360
post Oct 20 2014, 06:24 PM
914 Neferati
QUOTE(Jake Raby @ Oct 20 2014, 07:47 AM) *
Best,
Alex
Damn! That thing looks like it would bite if you got too close.
lexatola   Type 4 Store 2270   Oct 18 2014, 12:08 AM
Vacca Rabite   Different engines built to different specs using d...   Oct 18 2014, 03:05 AM
Harpo   I was not aware that they started selling engine k...   Oct 18 2014, 04:23 AM
Mark Henry   I was not aware that they started selling engine ...   Oct 18 2014, 07:19 AM
RobW   McMark. :mcmark:   Oct 18 2014, 05:48 AM
Mblizzard   They are. Looking around that store is like surfi...   Oct 18 2014, 06:09 AM
JStroud   You are correct, the type 4 store is now owned by ...   Oct 18 2014, 07:52 AM
lexatola   Thanks all for the confirmation that we think the ...   Oct 18 2014, 10:34 AM
Racer Chris   Thanks all for the confirmation that we think the...   Oct 18 2014, 12:05 PM
type47   Seems like if you take a 2.0 add headers, twin ca...   Oct 20 2014, 07:34 AM
r_towle   Thanks all for the confirmation that we think the...   Oct 21 2014, 08:33 AM
McMark   I find that looking at the HP numbers is just conf...   Oct 18 2014, 11:25 AM
Mark Henry   A header is the cheapest boost in HP and it's ...   Oct 18 2014, 12:41 PM
ConeDodger   I find that looking at the HP numbers is just con...   Oct 18 2014, 01:40 PM
Mikey914   Exponential power to price curve. Pick your sweet ...   Oct 18 2014, 12:06 PM
Hank914   What is there for a slight bump in HP if you want ...   Oct 18 2014, 01:16 PM
Mark Henry   What is there for a slight bump in HP if you want...   Oct 18 2014, 01:27 PM
Hank914   What is there for a slight bump in HP if you wan...   Oct 18 2014, 02:13 PM
Mark Henry   Thanks for the reply. Yes, I saw that. I shoul...   Oct 18 2014, 04:38 PM
lexatola   Thanks again for the continued activity. I like t...   Oct 18 2014, 05:00 PM
Vacca Rabite   Thanks again for the continued activity. I like ...   Oct 18 2014, 08:23 PM
76-914   Thanks again for the continued activity. I like...   Oct 20 2014, 08:24 AM
r_towle   Thanks again for the continued activity. I like ...   Oct 19 2014, 07:37 AM
rmdinmd   [quote name='Hank914' post='2099544...   Oct 19 2014, 06:38 AM
Mark Henry   I have been thinking about adding an oil cooler ...   Oct 19 2014, 09:51 AM
Racer Chris   Heat exchangers and fuel fired heaters have been ...   Oct 19 2014, 06:53 PM
Jake Raby   I'm getting close to pulling the trigger on t...   Oct 20 2014, 08:47 AM
KELTY360   [quote name='lexatola' post='2099298' date='Oct 1...   Oct 20 2014, 06:24 PM
malcolm2   Jake did you have this car at the tail of the...   Oct 22 2014, 07:05 PM
Jake Raby   Jake did you have this car at the tail of th...   Oct 22 2014, 07:59 PM
r_towle   Please do a thread on that car Jake.... I would lo...   Oct 20 2014, 05:40 PM
Jake Raby   Please do a thread on that car Jake.... I would l...   Oct 20 2014, 10:18 PM
lexatola   Here's my Outlaw.....Just for fun!   Oct 20 2014, 10:24 PM
lexatola   I have to say, being brand spanking new to the 914...   Oct 20 2014, 10:48 PM
McMark   :rolleyes:   Oct 21 2014, 01:32 AM
Dave_Darling   Another factor is that the 911 and 356 performance...   Oct 21 2014, 09:46 AM
SchwarzHorse   And if you install an engine manufactured by anoth...   Oct 21 2014, 01:25 PM
Mark Henry   And if you install an engine manufactured by anot...   Oct 21 2014, 01:50 PM
DBCooper   And prepare to stop telling people that you drive...   Oct 21 2014, 01:57 PM
RobW   That's it. I'm joining the 924 club!   Oct 21 2014, 01:58 PM
mr2by4   That's it. I'm joining the 924 club! ...   Oct 21 2014, 02:25 PM
biosurfer1   That's it. I'm joining the 924 club! ...   Oct 21 2014, 03:36 PM
Jake Raby   People want to be "builders", but they w...   Oct 21 2014, 10:56 PM
lexatola   Lot's of great perspectives added to the subje...   Oct 22 2014, 09:23 AM
stugray   What I'm hoping to learn, as an example, is ...   Oct 22 2014, 04:30 PM
Mark Henry   Unless you are stroking it stick with the stock ro...   Oct 22 2014, 09:33 AM
DBCooper   Cam I like the WEB 163/86b Absolutely. Split dur...   Oct 22 2014, 05:01 PM
Vacca Rabite   The "easy" builds won't get you to y...   Oct 22 2014, 11:27 AM
Racer Chris   40 IDFs won't get you to 180 hp without lots o...   Oct 22 2014, 01:40 PM
rhodyguy   Lex, you should take the short trek to gig harbor ...   Oct 22 2014, 03:44 PM
r_towle   103mm pistons and cylinders (use forged Pistons, J...   Oct 22 2014, 04:52 PM
Jake Raby   If torque is more important than HP, then make a c...   Oct 22 2014, 06:21 PM
rdauenhauer   I have moved toward a 2.4L combo for my engine p...   Oct 22 2014, 10:13 PM
Jake Raby   No, the next generation combo is 82X97mm using my ...   Oct 22 2014, 11:13 PM
Sfreeman615   I purchased the 2270 kit and heads from the type4 ...   Oct 23 2014, 09:36 AM
nivekdodge   I was suearching and found this very old post. If ...   May 21 2026, 04:42 PM
6 User(s) are reading this topic (4 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 21st May 2026 - 07:52 PM
