GB - Clutch cable end the cable goes through, 2 correct size nuts, pulley, pulley bushing, and cable cover bellows., $22 for all I will have clutch cables available at $18 each as an option |
Mikey914 |
Oct 21 2014, 11:22 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So, I have made the end that the cable goes through as that's been running about $13 as I lost one of mine and had to replace it, so thought these were quite overpriced.
I decided to include 2 nuts as these are hard to find and using one with nylon will eventually give out over time. This happened to me at WCR 2012, and was a pain to deal with on the drive as a few of you may remember. If you tighten the 2 against each other you can get them to stay. Also made the pulley and the NLA bushing as these tend to both wear over time. I made the replacement out of delrin and it is sturdier than the OEM eliminating any flex of the pulley. The cable bellows is new also Option for the cable is $18 if you want to add it. I'm bringing in cables, and will have them in a few days, the other parts are made and on the shelf Really a great deal fro many hard to find and overpriced parts. Bump the thread and I'll put you down for a set. let me know if you want a cable. I will have 2 other GB's opening up soon and and you will be able to combine, one is for some interior parts that haven't been available in many years, the other is something we all can use, and is in the same area. So, who's interested ? Attached thumbnail(s) Attached image(s) |
craig downs |
Oct 22 2014, 08:15 AM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
I would like one including the cable
Lo-Fi Version | Time is now: 9th June 2024 - 09:25 PM |
