Lost Rocker Arm Spring Washer, Where'd that little bugger go??? |
BeatNavy |
Oct 25 2014, 07:30 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Even though I'm sure my neighbors LIKE the smoke my '72 teener makes when the oil leaks from the pushrod onto the heat exchanger, today I got around to replacing the offending push rod tube seals (cylinder 3). As I put the rocker assembly back on, getting the push rods to seat properly in the rocker arm cups was, as documented in other threads, a bit of challenge for the newbie. When I first started tightening the rocker assembly nuts back on I realized the rods weren't seated properly and started backing them off. But the rocker assembly was under some tension -- the nut came off and the spring washer launched itself somewhere. I don't know where that little bugger went and hid. Not on the heat exchanger, not in my hair, not on my overalls, not on the floor best I can tell. (IMG:style_emoticons/default/confused24.gif)
It's called a spring washer or spring plate, I believe. To me it looks like a plain old washer. It didn't appear to be a lock washer or even have a spring contour to provide tension. These look like what I'm looking for: Type IV Rocker Shaft Nut Kit My questions: can I run with a plain old washer for a short period of time or something I should be able to get at the hardware store? If not, where's the best place to source? I think my 'teener is getting a little too comfortable on jackstands... (IMG:style_emoticons/default/dry.gif) |
type47 |
Oct 26 2014, 06:13 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
... But the rocker assembly was under some tension --... Makes me wonder if you brought #3 cylinder up to TDC. I get alot of hardware from Lowes and Home Depot and probably got these at one of those. You're welcome to any you need here in Vienna (IMG:style_emoticons/default/idea.gif) |
BeatNavy |
Oct 26 2014, 06:33 AM
... But the rocker assembly was under some tension --... Makes me wonder if you brought #3 cylinder up to TDC. I get alot of hardware from Lowes and Home Depot and probably got these at one of those. You're welcome to any you need here in Vienna (IMG:style_emoticons/default/idea.gif) That's awesome, Jim. I may have to make a road trip! And, no, I did not bring #3 up to TDC even though I knew I probably should have (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 08:48 AM |
