> How to Get Engine onto Engine Stand?
VWTortuga336
post Oct 29 2014, 08:16 AM
This may have already been covered, but I haven't had any luck figuring my problem out. I've got my engine pulled, tranny separated and the engine is on my ATV jack. I just bought an engine stand and now I can't figure out how to mount the engine to it (IMG:style_emoticons/default/headbang.gif) The ATV jack won't raise high enough to get all 4 mounting points to line up. And, the base of the stand won't allow the stand to get close enough to the engine, due to the base of the jack.
Anyone have any tricks they could share?
r_towle
post Oct 29 2014, 08:25 AM
Custom Member
First off you need a porsche/VW head for the engine stand.
That head you have with the four arms will not fit and will rub against the flywheel....
It will also not mount flush unless you notch the ends of the tubes around the case.
For an answer to your question, remove the head from the stand and mount it to the motor.
Either get a helper, or some rope from above to balance things and tip the engine stand over until you can slide the large tube into the engine stand.
Then slowly tip it upright.
Stripped, the motor can be lifted from the floor.
So, when you mount it on the engine stand like I said, you can do this yourself, it just take planning, chock the wheels on the engine stand when you tip it so it does not slide out while you are lifting it.
It's not a lot of drama is you take your time.
The correct head for the engine can be purchase at any VW shop.
The more rugged ones are available at "mainly by design"
Rich
VWTortuga336   How to Get Engine onto Engine Stand?   Oct 29 2014, 08:16 AM
type47   You could take the yoke off the stand and over to ...   Oct 29 2014, 08:22 AM
bandjoey   and a few friends with muscles! Ebay has seve...   Oct 29 2014, 08:24 AM
r_towle   First off you need a porsche/VW head for the engin...   Oct 29 2014, 08:25 AM
r_towle   Seeing as you have a three wheel engine stand, you...   Oct 29 2014, 08:31 AM
VWTortuga336   Thanks for all the suggestions. Anyone in the KC,...   Oct 29 2014, 09:34 AM
McMark   Thanks for all the suggestions. Anyone in the KC...   Oct 29 2014, 10:21 AM
Phoenix914   Thanks for all the suggestions. Anyone in the K...   Oct 29 2014, 10:26 AM
stugray   Mount the yoke to the engine first. Leave the engi...   Oct 29 2014, 10:40 AM
bandjoey   The cheap one for the once in 10 year rebuilder.   Oct 29 2014, 10:44 AM
914Sixer   I put a sling around the engine. Install engine ...   Oct 29 2014, 04:22 PM
maf914   I Throw a chain around tree limb, attach wench, a...   Oct 30 2014, 05:46 AM
CatDaddy60   I used to pick up the engine after bolting the yol...   Oct 29 2014, 04:48 PM
DBCooper   This thread is great. I've always just muscle...   Oct 29 2014, 05:34 PM
r_towle   Hate to say it, but now that I have a lift I have ...   Oct 29 2014, 05:54 PM
914Sixer   Sometimes I my fingers don"t match what I am ...   Oct 30 2014, 06:07 AM
Edchina   I use a chain hoist and an attachement to handle...   Oct 30 2014, 06:33 AM
carr914   Hate to say it, but now that I have a lift I have...   Oct 30 2014, 06:53 AM
Vacca Rabite   Hand crank winch and a pulley hanging off a rafter...   Oct 30 2014, 08:16 PM
mapguy   I got the cheap chain hoist at HF and use one of t...   Oct 30 2014, 09:49 PM
- Lo-Fi Version Time is now: 16th April 2026 - 10:39 PM
