| EJP914 |
Nov 1 2014, 10:26 AM
Member ![]() ![]() Group: Members Posts: 290 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Could someone please tell me how to remove this seal from the housing? This housing holds the shaft and gear that go into the transaxle and the angle drive screws into it. The Porsche replacement seal (99911303650) seems to very stiff and rigid. I thought this seal would be a flexible rubber and pull out easily and pop the new one in. And the new one looks way larger than the hole it sits in. It doesn't bend or compress in from the side.
Before I tore it all up, thought I would ask the experts. All suggestions and guidance are appreciated. EJP Attached image(s)
| EdwardBlume |
Nov 1 2014, 10:53 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
i was going to tell you to suck on it.. (IMG:style_emoticons/default/av-943.gif)
EJP914 seal removal ? Nov 1 2014, 10:26 AM
EJP914 I figured it out. There is an aluminum washer over... Nov 1 2014, 10:40 AM
Mikey914 Putting the new one in is tight also. I covered th... Nov 1 2014, 10:45 PM
barefoot Just got my old seal out. Removing the Aluminum w... Nov 21 2014, 11:51 AM![]() ![]() |
Lo-Fi Version | Time is now: 6th June 2026 - 11:38 PM |
