| r_towle |
Nov 4 2014, 07:45 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
When prepping a car for sandblasting, what is the common thing to do with the aluminum tags in the front trunk and door pillar?
I suppose the second question would be do I acid dip the car or get it sandblasted? |
| mepstein |
Nov 4 2014, 08:24 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I wouldn't acid dip. You'll never be able to protect the spot welded seams.
r_towle Body sand blasting or acid dipping Nov 4 2014, 07:45 AM
cn2800 I very carefully drilled out the rivets for those ... Nov 4 2014, 07:59 AM
r_towle
I very carefully drilled out the rivets for those... Nov 4 2014, 08:11 AM
partwerks
I very carefully drilled out the rivets for thos... Nov 8 2014, 07:29 PM
r_towle
I wouldn't acid dip. You'll never be able... Nov 4 2014, 08:33 AM
rudedude Seeing the damage done to a 356 from dapo that I a... Nov 4 2014, 08:32 AM
stevegm :popcorn:
I researched this pretty well a while ... Nov 4 2014, 08:36 AM
altitude411 Plastic bead media blasting is the way to go in my... Nov 4 2014, 08:40 AM
rgalla9146
When prepping a car for sandblasting, what is the... Nov 4 2014, 03:19 PM
rick 918-S http://www.914world.com/bbs2/index.php?sho...=2303... Nov 4 2014, 04:10 PM
CptTripps
[url=http://www.914world.com/bbs2/index.php?showt... Nov 7 2014, 09:01 AM
SixerJ
[url=http://www.914world.com/bbs2/index.php?show... Nov 8 2014, 03:25 AM
McMark
Quite possibly a stupid suggestion - why not cut ... Nov 9 2014, 10:47 AM
balljoint I get sand all over the dash every time I turn the... Nov 4 2014, 04:29 PM
SixerJ Maybe useful background info, but unfortunately do... Nov 5 2014, 05:05 PM
r_towle Interesting note, the initial dip is a BASE.
The ... Nov 5 2014, 05:37 PM
lsintampa I acid dipped....
Then por-15 the entire car...
... Nov 5 2014, 06:00 PM
Mikey914 I've used soda blasting to spot clean a few ar... Nov 5 2014, 11:32 PM
SirAndy Whatever you do, don't use sand to blast your ... Nov 6 2014, 11:09 AM
lsintampa Sand will get into everything, for sure. Ever go ... Nov 6 2014, 11:32 AM
r_towle My plan, either way, is to strip it to the tub and... Nov 6 2014, 06:30 PM
Katmanken And you can do the electrolysis process on a whole... Nov 6 2014, 06:31 PM
Phoenix-MN
And you can do the electrolysis process on a whol... Nov 7 2014, 07:26 AM
r_towle I am starting to lean toward dipping the car, then... Nov 6 2014, 06:35 PM
roblav1 I just went through this. Aircraft stripper - let... Nov 7 2014, 12:59 AM
amfab
I just went through this. Aircraft stripper - le... May 16 2017, 03:01 PM
boxsterfan Take the floors out. There is rust in the seams. ... Nov 7 2014, 04:33 PM
Jon H. If you spray you high build primer on top of the e... Nov 8 2014, 08:45 AM
veekry9 Redi-Strip.
http://www.redi-strip.com/
https://w... Nov 8 2014, 08:13 PM
veekry9 Come to think of it,I haven't come across anyo... Nov 8 2014, 08:24 PM
Maltese Falcon Had our current- build blasted with garnet sand. T... Nov 8 2014, 09:57 PM
r_towle So, a few years have passed. What does everyone th... May 15 2017, 10:27 PM
bulitt
So, a few years have passed. What does everyone t... May 16 2017, 06:58 AM
r_towle Best/sad part of this is I was searching for any t... May 15 2017, 10:35 PM
McMark Blasting for me. May 16 2017, 06:38 AM
6freak
Blasting for me.
with ice! look into that... May 16 2017, 02:20 PM
Perry Kiehl If you have a really rusty shell, then dip it, but... May 16 2017, 10:16 AM
rgalla9146
If you have a really rusty shell, then dip it, bu... May 16 2017, 12:43 PM
jimkelly the question i have about acid dip is that all pai... May 16 2017, 06:24 PM
Tdskip
the question i have about acid dip is that all pa... Mar 23 2021, 03:52 PM
bulitt Rich: talk to Scotty. He has the dustless set up a... May 17 2017, 07:40 AM
Rich: talk to Scotty. He has the dustless set up ... May 17 2017, 07:57 AM
r_towle I am not doing this project, I will sub contract i... May 17 2017, 08:07 AM
cary On Doug's project we went with soda blasting, ... May 17 2017, 08:20 AM
roblav1 My old car is the white one in the rotisserie. I... Sep 2 2017, 06:21 PM
mepstein I've been thinking about this. the 911 chassis... Sep 2 2017, 07:44 PM
CptTripps ::: digging up an old topic, so I don't have t... Mar 23 2021, 09:37 AM
ClayPerrine
::: digging up an old topic, so I don't have ... Mar 23 2021, 09:47 AM
Root_Werks :agree:
If you want to dip, prepare the body for... Mar 23 2021, 10:02 AM
mepstein Plastic media blasting worked well for us when I w... Mar 23 2021, 10:07 AM
worn
Plastic media blasting worked well for us when I ... Mar 23 2021, 03:46 PM
Cairo94507 I would do media blasting and ask the blaster what... Mar 23 2021, 04:22 PM
Tdskip
I would do media blasting and ask the blaster wha... Mar 23 2021, 05:09 PM
ClayPerrine
I would do media blasting and ask the blaster wh... Mar 23 2021, 08:25 PM
Luke M This thread came up at the right time. I just met ... Mar 24 2021, 05:04 AM
Cairo94507 I agree re the dry ice blasting, but I think that ... Mar 24 2021, 07:30 AM
930cabman I would not dip, there are too many hollow section... Mar 24 2021, 07:46 AM
mate914 I used baking soda mixed with aluminum oxide on ni... Mar 24 2021, 09:36 AM
PanelBilly I used some plumbing plugs to seal off the heater ... Mar 24 2021, 01:24 PM
914werke Both media blasted (dry) and soda blasted (wet) a ... Mar 24 2021, 05:01 PM
racerbvd Back when you could reasonably get a tub acid dipp... Mar 24 2021, 05:17 PM
GeorgeKopf I'm going to acid dip my 1974 chassis.
I foun... Mar 24 2021, 06:10 PM
gandalf_025 This is what my car looked like when it came back ... Mar 25 2021, 12:02 PM
930cabman
This is what my car looked like when it came back... Mar 25 2021, 12:53 PM
d914 I did soda on my car.. worked well.. Just needs a ... Mar 25 2021, 12:10 PM
gandalf_025 Car looks more like this now..
It was painted imme... Mar 25 2021, 01:09 PM
It was painted imm... Mar 25 2021, 03:33 PM
gandalf_025 I wasn’t involved in the blasting process.
The b... Mar 25 2021, 04:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:49 AM |
