| r_towle |
Nov 4 2014, 07:45 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
When prepping a car for sandblasting, what is the common thing to do with the aluminum tags in the front trunk and door pillar?
I suppose the second question would be do I acid dip the car or get it sandblasted? |
| r_towle |
Nov 5 2014, 05:37 PM
Interesting note, the initial dip is a BASE.
The acid dip, typically phosphoric acid, is down to neutralize the base and stop the process from continuing. Phosphoric acid also helps stop rust from continuing...same reason. Then wash it off with water... So the car sits for a long time in a base solution, and is dipped pretty fast into an acid bath. Now I want to go out and weigh a small piece of sheet metal and put it into phosphoric acid for a week to see what happens. Rich |
r_towle Body sand blasting or acid dipping Nov 4 2014, 07:45 AM
cn2800 I very carefully drilled out the rivets for those ... Nov 4 2014, 07:59 AM
r_towle
I very carefully drilled out the rivets for those... Nov 4 2014, 08:11 AM
partwerks
I very carefully drilled out the rivets for thos... Nov 8 2014, 07:29 PM
mepstein I wouldn't acid dip. You'll never be able ... Nov 4 2014, 08:24 AM
r_towle
I wouldn't acid dip. You'll never be able... Nov 4 2014, 08:33 AM
rudedude Seeing the damage done to a 356 from dapo that I a... Nov 4 2014, 08:32 AM
stevegm :popcorn:
I researched this pretty well a while ... Nov 4 2014, 08:36 AM
altitude411 Plastic bead media blasting is the way to go in my... Nov 4 2014, 08:40 AM
rgalla9146
When prepping a car for sandblasting, what is the... Nov 4 2014, 03:19 PM
rick 918-S http://www.914world.com/bbs2/index.php?sho...=2303... Nov 4 2014, 04:10 PM
CptTripps
[url=http://www.914world.com/bbs2/index.php?showt... Nov 7 2014, 09:01 AM
SixerJ
[url=http://www.914world.com/bbs2/index.php?show... Nov 8 2014, 03:25 AM
McMark
Quite possibly a stupid suggestion - why not cut ... Nov 9 2014, 10:47 AM
balljoint I get sand all over the dash every time I turn the... Nov 4 2014, 04:29 PM
SixerJ Maybe useful background info, but unfortunately do... Nov 5 2014, 05:05 PM
lsintampa I acid dipped....
Then por-15 the entire car...
... Nov 5 2014, 06:00 PM
Mikey914 I've used soda blasting to spot clean a few ar... Nov 5 2014, 11:32 PM
SirAndy Whatever you do, don't use sand to blast your ... Nov 6 2014, 11:09 AM
lsintampa Sand will get into everything, for sure. Ever go ... Nov 6 2014, 11:32 AM
r_towle My plan, either way, is to strip it to the tub and... Nov 6 2014, 06:30 PM
Katmanken And you can do the electrolysis process on a whole... Nov 6 2014, 06:31 PM
Phoenix-MN
And you can do the electrolysis process on a whol... Nov 7 2014, 07:26 AM
r_towle I am starting to lean toward dipping the car, then... Nov 6 2014, 06:35 PM
roblav1 I just went through this. Aircraft stripper - let... Nov 7 2014, 12:59 AM
amfab
I just went through this. Aircraft stripper - le... May 16 2017, 03:01 PM
boxsterfan Take the floors out. There is rust in the seams. ... Nov 7 2014, 04:33 PM
Jon H. If you spray you high build primer on top of the e... Nov 8 2014, 08:45 AM
veekry9 Redi-Strip.
http://www.redi-strip.com/
https://w... Nov 8 2014, 08:13 PM
veekry9 Come to think of it,I haven't come across anyo... Nov 8 2014, 08:24 PM
Maltese Falcon Had our current- build blasted with garnet sand. T... Nov 8 2014, 09:57 PM
r_towle So, a few years have passed. What does everyone th... May 15 2017, 10:27 PM
bulitt
So, a few years have passed. What does everyone t... May 16 2017, 06:58 AM
r_towle Best/sad part of this is I was searching for any t... May 15 2017, 10:35 PM
McMark Blasting for me. May 16 2017, 06:38 AM
6freak
Blasting for me.
with ice! look into that... May 16 2017, 02:20 PM
Perry Kiehl If you have a really rusty shell, then dip it, but... May 16 2017, 10:16 AM
rgalla9146
If you have a really rusty shell, then dip it, bu... May 16 2017, 12:43 PM
jimkelly the question i have about acid dip is that all pai... May 16 2017, 06:24 PM
Tdskip
the question i have about acid dip is that all pa... Mar 23 2021, 03:52 PM
bulitt Rich: talk to Scotty. He has the dustless set up a... May 17 2017, 07:40 AM
Rich: talk to Scotty. He has the dustless set up ... May 17 2017, 07:57 AM
r_towle I am not doing this project, I will sub contract i... May 17 2017, 08:07 AM
cary On Doug's project we went with soda blasting, ... May 17 2017, 08:20 AM
roblav1 My old car is the white one in the rotisserie. I... Sep 2 2017, 06:21 PM
mepstein I've been thinking about this. the 911 chassis... Sep 2 2017, 07:44 PM
CptTripps ::: digging up an old topic, so I don't have t... Mar 23 2021, 09:37 AM
ClayPerrine
::: digging up an old topic, so I don't have ... Mar 23 2021, 09:47 AM
Root_Werks :agree:
If you want to dip, prepare the body for... Mar 23 2021, 10:02 AM
mepstein Plastic media blasting worked well for us when I w... Mar 23 2021, 10:07 AM
worn
Plastic media blasting worked well for us when I ... Mar 23 2021, 03:46 PM
Cairo94507 I would do media blasting and ask the blaster what... Mar 23 2021, 04:22 PM
Tdskip
I would do media blasting and ask the blaster wha... Mar 23 2021, 05:09 PM
ClayPerrine
I would do media blasting and ask the blaster wh... Mar 23 2021, 08:25 PM
Luke M This thread came up at the right time. I just met ... Mar 24 2021, 05:04 AM
Cairo94507 I agree re the dry ice blasting, but I think that ... Mar 24 2021, 07:30 AM
930cabman I would not dip, there are too many hollow section... Mar 24 2021, 07:46 AM
mate914 I used baking soda mixed with aluminum oxide on ni... Mar 24 2021, 09:36 AM
PanelBilly I used some plumbing plugs to seal off the heater ... Mar 24 2021, 01:24 PM
914werke Both media blasted (dry) and soda blasted (wet) a ... Mar 24 2021, 05:01 PM
racerbvd Back when you could reasonably get a tub acid dipp... Mar 24 2021, 05:17 PM
GeorgeKopf I'm going to acid dip my 1974 chassis.
I foun... Mar 24 2021, 06:10 PM
gandalf_025 This is what my car looked like when it came back ... Mar 25 2021, 12:02 PM
930cabman
This is what my car looked like when it came back... Mar 25 2021, 12:53 PM
d914 I did soda on my car.. worked well.. Just needs a ... Mar 25 2021, 12:10 PM
gandalf_025 Car looks more like this now..
It was painted imme... Mar 25 2021, 01:09 PM
It was painted imm... Mar 25 2021, 03:33 PM
gandalf_025 I wasn’t involved in the blasting process.
The b... Mar 25 2021, 04:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:22 AM |
