| hunterhwt |
Nov 6 2014, 06:32 PM
Newbie ![]() Group: Members Posts: 6 Joined: 6-November 14 From: United States Member No.: 18,093 Region Association: Rocky Mountains |
Hello everyone,im new to the forum and in Colorado springs,i purchased a 73 ,914 in the last 4 months.Its a project car and i want it to be my summer daily driver so im doing alot of work on it this winter.when i got it ,it did not run i got it to start after rebuilding the carbs(i guess i should tell you it has twin 40 weber carbs) only to find out that #4 cylinder held no presure.the intake valve was bent and would not close all the way,So no little task to pull engine and trans have heads machined and valve done and finally to get it back in after a few problems.But its in and now i cant get the gas pedal to work when i push it in it stays down or comes up very slow.ive checked the carb linkage and with the spring on it works fine.I checked down by pedale to see if anything is stuck i cant see anything?? im a bit lost i need some idea and its tough to find someone here whos can work on these cars.and on a side note i need to install the rear window what seals do i need pelican parts does not show one thanks.
| brant |
Nov 7 2014, 05:52 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,159 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
I agree with chris. Likely the pedals need to be rebuilt and you can do this job yourself easily
Welcome to teener-Dom You should consider joining our colorado yahoo list. We have get together from time to time. (Dinner this Saturday in Denver) colorado-914@yahoogroups.com |
hunterhwt throttle linkage Nov 6 2014, 06:32 PM
sb914
Hello everyone,im new to the forum and in Colorad... Nov 6 2014, 06:47 PM
G e o r g e
on a side note i need to install the rear window ... Nov 6 2014, 06:51 PM
r_towle If it worked before, you may have either wrapped t... Nov 6 2014, 06:53 PM
Mike Bellis :wttc:
:ttiwwp:
:D Nov 6 2014, 06:59 PM
Racer Chris
i cant get the gas pedal to work when i push... Nov 6 2014, 07:09 PM
hunterhwt Thankyou all for the ideas I will try them the onl... Nov 7 2014, 09:09 AM
RobW :wttc: Nov 7 2014, 09:31 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 01:13 PM |
