> Stub axles, hubs, ?s
Qarl
post May 2 2003, 03:55 PM
Shriveled member
My race shop guy is helping me put together my driveline for my six conversion.
He would like me to use '72/'73 axles for the rear, which will necessitate changing the output flanges for the tranny, and the stub axles as well.
He says the '72/'73 axles are different than the '71 and earlier axles. However, I can't seem to find differentiation from any of the parts houses.
Are the '72/'73 STUB axles different than other early (i.e.. 69 to 71) stub axles or can I use '70 stub axles to mate to the '72/'73 axles?
Also, will these stub axles fit into a 914 hub that is drilled for five bolts, or do I need to find '72/73 hubs as well (i.e., is there a spline difference)?
What about the the output flanges for the tranny? He says I need to find the 901 output flanges from a 911 from the same year as the axles. Something about length differences.
Brad, you're a guru in this area?
What do I have to locate?
Brad Roberts
post May 2 2003, 04:19 PM
914 Freak!
Nothing.
Shoot me 400$ and I will send you everything but the axles you need.
I stock this stuff and buy it every time I see it at a swap meet.
I can get you the axle part number on Monday that I use. NO spacers needed.
I have the early hubs/stubs and drive flanges for the 901. They are crusty and old, but I will clean them up for you. The control arm drive flanges slide right into a 914 wheel bearing.
B
- Lo-Fi Version Time is now: 6th July 2025 - 10:07 AM
