> Interior remodeling
rtalich
post Nov 9 2014, 10:46 AM
Found a big block of foam and thought I would see about making my own center console. Here's the progress so far. This will be my first project using fiberglass... any pointers or advice? Should I use cloth or mat? Should I paint or use color resin?
Thanks
Rob
rtalich
post Nov 10 2014, 02:31 PM
Thanks for all the suggestions so far!! At this point I'm thinking I will bondo over the foam and get a nice good base. Then fabric or CF over that. Then several coats of resin sanding in between to get a nice smooth surface. I will probably cut the peice to make a lid and compartment before bondo and glass.
I found this block of foam while driving by a place a while ago. They were throwing a bunch of these blocks out. Asked if I can have one. I've had it in the garage for a coulple years and decided it's time to make something out of it.
ThePaintedMan
post Nov 11 2014, 08:08 PM
QUOTE(rtalich @ Nov 10 2014, 03:31 PM) *
Your idea looks awesome so far, but I think you have it a little backward (at least from how folks typically fabricate). Foam first. Then lay your fiberglass over. Then finish with bondo and primer.
You don't want to lay bondo over the foam because it won't have a firm surface to adhere to. This could be a real problem as it sits in the sun and cures over the years.
Generally when you make a one-off part you always finish fiberglass with a skim coat of bondo/filler. Resin by itself won't leave you with a great surface to prime and paint without roughing it up. And trying to sand resin with anything finer than 120 grit is basically pointless. That's why your final step will always be bondo and primer. Unless of course you have a mold, like Mark was talking about. Then no filler should be necessary - just gel coat.
rtalich   Interior remodeling   Nov 9 2014, 10:46 AM
McMark   Mat will work fine. Don't try to do it all in...   Nov 9 2014, 10:53 AM
McMark   Oh and you might as well stick a 6.5" subwoof...   Nov 9 2014, 10:55 AM
rtalich   Thanks Mark! If I used cloth and then a few co...   Nov 9 2014, 12:03 PM
PanelBilly   Wrap it in vinyl and make an upholstered cap   Nov 9 2014, 12:12 PM
porschefile2010   Interesting job ahead of you. Regardless of what y...   Nov 9 2014, 12:19 PM
Bob L.   How are you going to Handle the hole for the shift...   Nov 9 2014, 12:27 PM
veekry9   http://www.fiero.nl/forum/Forum3/HTML/000091-53.ht...   Nov 9 2014, 04:45 PM
barefoot   Recommend using epoxy. I've used quite a bi...   Nov 10 2014, 11:41 AM
rtalich   How are you going to Handle the hole for the shif...   Nov 9 2014, 06:01 PM
McMark   Just plan on using bondo, cause it's gonna hap...   Nov 9 2014, 06:39 PM
CptTripps   Very cool. Where can I buy some of this foam? That...   Nov 10 2014, 12:56 PM
altitude411   Very cool. Where can I buy some of this foam? Tha...   Nov 11 2014, 07:59 PM
veekry9   http://www.freemansupply.com/ http://www.freemans...   Nov 10 2014, 01:34 PM
rtalich   Thanks for all the suggestions so far!! At...   Nov 10 2014, 02:31 PM
ThePaintedMan   Thanks for all the suggestions so far!! A...   Nov 11 2014, 08:08 PM
porschefile2010   And for a first time amateur build I really think ...   Nov 12 2014, 12:19 PM
barefoot   And for a first time amateur build I really think...   Nov 12 2014, 05:08 PM
rtalich   A bit more progress.   Nov 11 2014, 06:34 PM
rtalich   Thanks!!! I will follow the steps and ...   Nov 12 2014, 12:33 PM
McMark   Consider some access to adjust the shifter. If yo...   Nov 12 2014, 12:50 PM
G e o r g e   are you going to incorporate a spot for the SDS co...   Nov 12 2014, 02:00 PM
rtalich   are you going to incorporate a spot for the SDS c...   Nov 12 2014, 02:08 PM
914bub   Although I may not... probably going to be switc...   Nov 22 2014, 07:27 PM
veekry9   http://www.fisheriessupply.com/resins-and-...ies/e...   Nov 12 2014, 02:23 PM
76-914   http://www.fisheriessupply.com/resins-and-...ies/...   Nov 22 2014, 08:13 PM
rtalich   Some progress. I brushed on a few coats of white w...   Nov 21 2014, 05:13 PM
rtalich   Before:   Nov 21 2014, 05:13 PM
rtalich   After:   Nov 21 2014, 05:14 PM
rtalich   One more. Ready for glass. I am leaning toward co...   Nov 21 2014, 05:19 PM
Andyrew   Very nice! Thats almost marketable!   Nov 21 2014, 05:57 PM
scotty b   Very nice! Thats almost marketable! :ag...   Nov 21 2014, 06:14 PM
Chris914n6   Did you compensate for the thickness of the glass/...   Nov 21 2014, 06:35 PM
rtalich   Very nice! Thats almost marketable! [qu...   Nov 22 2014, 01:05 PM
914Sixer   What about using the heat shrink type material use...   Nov 22 2014, 05:20 PM
rtalich   What about using the heat shrink type material us...   Nov 22 2014, 07:00 PM
altitude411   [quote name='914Sixer' post='2113665' date='Nov 2...   Nov 22 2014, 08:57 PM
914Sixer   No link but Google is probably able to help find t...   Nov 22 2014, 07:59 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:21 PM
