> Aussie 914 Restoration
barrym
post Oct 26 2014, 04:05 PM
First time post of lurking here for a while.
I bought a '75 914 a couple of weeks ago that had already been partly pulled apart to restore- its mostly complete but needs to be further pulled down to repair the rust & make mods to it for my intended purpose.
it already came as right hand drive and has an amazingly good condition dash board. I have no history with the car so cant tell who or when the conversion was done. I don't even know if it was a US or European import, or if it was an aussie delivered car ... how can I tell ???
it has a scallop out of the right hand side chassis rail for the handbrake, but not the left hand side ...
it used to be viper green and has had a poor respray in red - it's going back to viper green (IMG:style_emoticons/default/smile.gif)
I have some garage space with a couple of chaps who has worked on 14's before which is a HUGE help to me, very lucky as i'm new to Porsche having owned lotus's for years (and still do). the plan is to restore it for partial road use but mostly track & tarmac rally. in the short term I plan to drop a 3.0 Subaru engine in while I build up funds & parts for a 2.7 Porsche engine.
Its been in dry storage for at least 11 years than I know of, and possibly more before that.
anyway, am documenting my rebuild thread here.
I've made a start on removing the hacked up loom & vacuuming all the loose rust out. Its better than expected (as I bought the car only from pictures)
it needs;
new hell holes
back of floorpan & bottom of firewall
boot
and that's about it - the rest of it looks (at this stage) like only surface rust - the suspension consoles are solid as is the majority of the front boot - again, only surface rust there ...
the windscreen will come out next to get access to pull out the dash so I can continue to remove the loom.
i'll be making up a new loom for it.
question though - how do I remove the left hand seat ? the lever at the side does nothing - possibly broken ? and there is no handle at the front to slide the seat forwards to get at the rear bolts ... stumped on this one ...
barrym
post Nov 12 2014, 04:36 PM
couple of nice large boxes arrived for me over the last couple of days .. (IMG:style_emoticons/default/smile.gif)
Roof, engine lid, boot floor, window cranks, rear light buckets & lens, floor mount pedal box, headlights, front indicator buckets & lens
still need to order some brake lines & fuel lines tho ...
but I have sourced what I think is a complete kit for the Subaru gearbox conversion ...
Subarugears (Australia based as well) make a mid mount conversion kit - http://www.subarugears.com/index_files/Products.html
they do a bunch of other stuff too that may interest Porsche owners ..
Anyway, the 914 CV joint is about 90mm diameter, this conversion kit requires 100mm joints, but the VW kombi van is apparently a direct slip onto the 914 driveshaft and is a 100mm CV.
this makes a complete mid mount conversion to 2wd & 914 kit around $1100 aussie $ - well, plus the gear shift mechanism ...
pretty good value I think ...
can anyone comment on using kombi CV joints ?
barrym   Aussie 914 Restoration   Oct 26 2014, 04:05 PM
76-914   :wttc: You'd better not drive that thing with ...   Oct 26 2014, 05:20 PM
Betty   :wttc: :ttiwwp: Howdy from Texas!   Oct 26 2014, 06:40 PM
Mike Bellis   :wttc:   Oct 26 2014, 06:58 PM
porschefile2010   That doesn't look too bad at all. I've see...   Oct 26 2014, 07:27 PM
edwin   I was watching that one on eBay good to see it...   Oct 26 2014, 07:59 PM
abnrdo   :wttc: Nice car color! You have a rare one ...   Oct 26 2014, 08:29 PM
rick 918-S   Viper! :drooley: :wttc: :assimilate:   Oct 26 2014, 09:11 PM
barrym   Thanks all .. the 2.7 idea is essentially require...   Oct 26 2014, 09:19 PM
Dave_Darling   Let's see. US-spec models would have the ...   Oct 27 2014, 10:41 AM
Downunderman   It's good to have another teener in the histor...   Oct 27 2014, 11:17 AM
johnnymagoo   A company called Crayford in the UK offered a RHD ...   Oct 27 2014, 02:25 PM
barrym   :) little more progress last night - got the wind...   Oct 27 2014, 02:55 PM
mein_tag   Really like the color!   Oct 27 2014, 05:26 PM
barrym   A little more work last night was very successful ...   Oct 28 2014, 03:23 PM
barrym   little more progress today; did a little worksho...   Oct 31 2014, 11:47 PM
venturadeb   little more progress today; Removed both rear se...   Nov 5 2014, 06:27 AM
al weidman   A fiberglass door skin will not help much on a US ...   Nov 1 2014, 10:00 AM
barrym   Can the crash bars be removed without splitting th...   Nov 1 2014, 01:18 PM
Dave_Darling   Can the crash bars be removed without splitting t...   Nov 4 2014, 10:20 AM
barrym   small update - i have a spare shifter tunnel ...   Nov 3 2014, 10:11 PM
dale73914   Hey Barry, Looks good, especially those sills. ...   Nov 5 2014, 06:12 AM
barrym   Thanks Dale - i shall investigate them, although h...   Nov 6 2014, 04:47 PM
barrym   some of the firewall replaced ... and picked up a...   Nov 6 2014, 09:22 PM
barrym   a few big days of work this week ... where do I b...   Nov 9 2014, 06:25 PM
barrym   couple of nice large boxes arrived for me over the...   Nov 12 2014, 04:36 PM
barrym   been a few weeks since updates - have been away wi...   Nov 25 2014, 05:56 PM
barrym   been a few weeks since the last update - but have ...   Dec 22 2014, 04:39 PM
crsedge   Hi Barry, Great work! And Viper Green- great c...   Jan 3 2015, 02:22 PM
barrym   thx :) although I recently found out it is not vi...   Jan 4 2015, 07:16 PM
rgalla9146   thx :) although I recently found out it is not v...   Nov 9 2015, 07:15 PM
barrym   thx :) although I recently found out it is not ...   Nov 11 2015, 05:27 AM
barrym   Finally I can get started on this again- had to mo...   Nov 6 2015, 06:32 PM
veekry9   Loti The plural of Lotus. :D Confronted the conun...   Nov 7 2015, 04:30 AM
maf914   Loti The plural of Lotus. :D Confronted the conu...   Nov 9 2015, 11:59 AM
Cairo94507   Nice progress and work. :smash: :shoot2kill: :...   Nov 7 2015, 08:26 AM
barrym   Veekry9 : that pic was at Winton (around 8-10 hour...   Nov 8 2015, 11:28 PM
veekry9   This restore is a major task. A cornucopia of idea...   Nov 8 2015, 11:39 PM
Andyrew   Great looking work! I must note I have never...   Nov 9 2015, 12:23 PM
barrym   Great looking work! I must note I have neve...   Nov 9 2015, 02:43 PM
veekry9   pNrnDlda5p8Thanks for the touraround,a chance to s...   Nov 9 2015, 01:33 PM
Andyrew   I see the rusted marks from the hammer for the ste...   Nov 9 2015, 03:56 PM
barrym   Boxster caliper stuff arrived today from rebel - a...   Nov 11 2015, 05:21 AM
Chris H.   Is your car titled as a 1975? Because it looks li...   Nov 11 2015, 07:08 AM
Nutter965   Looking good, i noticed yours had been converted t...   Nov 11 2015, 07:53 AM
76-914   Is your car titled as a 1975? Because it looks l...   Nov 11 2015, 09:04 AM
barrym   Is your car titled as a 1975? Because it looks ...   Nov 11 2015, 02:49 PM
Chris H.   It's the VIN number that tells you what model ...   Nov 11 2015, 03:34 PM
barrym   Ahh- that makes sense thanks :)   Nov 11 2015, 04:30 PM
barrym   Dash pics - it was basically chopped & welded ...   Nov 14 2015, 03:03 PM
Nutter965   Dash pics - it was basically chopped & welded...   Nov 14 2015, 03:36 PM
barrym   Dash pics - it was basically chopped & welde...   Nov 15 2015, 10:25 PM
barrym   Cross bar & control arm back from powder coati...   Nov 14 2015, 03:04 PM
barrym   I bought a my2000 wrx for the engine/ gearbox etc-...   Nov 14 2015, 03:06 PM
dale73914   I bought a my2000 wrx for the engine/ gearbox etc...   Nov 15 2015, 09:18 PM
barrym   Picked up a zinc plating & passivating kit - h...   Nov 29 2015, 01:10 AM
barrym   Managed to get a days work in last weekend and dec...   Dec 18 2015, 12:10 AM
barrym   Oh- and I repainted the cluster surround & ins...   Dec 18 2015, 12:29 AM
barrym   managed to get a few things done over the xmas bre...   Jan 20 2016, 03:59 PM
barrym   I've also been busy designing a circuit to fla...   Jan 20 2016, 04:08 PM
Saggas   hey barry! awesome to see an aussie restoratio...   Jan 20 2016, 04:14 PM
dale73914   hey barry! awesome to see an aussie restorati...   Jan 20 2016, 05:12 PM
barrym   nice .. a few thousand clicks north ... sunshine c...   Jan 20 2016, 04:18 PM
Larmo63   THIS is Viper Green: Your 914 would look good ...   Jan 20 2016, 06:28 PM
barrym   have been working on the front end a bit - got low...   Feb 24 2016, 02:43 AM
914forme   Loving this thread :popcorn:   Feb 24 2016, 07:22 AM
forrestkhaag   Hey Barry: Nice work / An immense undertaking. A...   Mar 4 2016, 01:33 PM
barrym   Hey Barry: Nice work / An immense undertaking. ...   Mar 29 2016, 05:15 AM
Michel   Barry enjoying the thread. And having just bought ...   Mar 8 2016, 11:45 AM
76-914   What a beautiful green. My favorite color. :wub: ...   Mar 29 2016, 01:04 PM
barrym   Well, have managed to get a few things done over t...   Apr 26 2016, 04:52 AM
barrym   have been making some solid progress over the last...   May 9 2016, 08:28 PM
barrym   I had to bend some sheet metal for the pedal box -...   May 9 2016, 08:34 PM
barrym   wow - time really does fly - looking at some of th...   Aug 24 2016, 01:39 AM
barrym   I needed to straighten the brake lines as it came ...   Aug 24 2016, 01:46 AM
barrym   have started to get busy with wiring - this was a ...   Aug 24 2016, 01:50 AM
barrym   also pulled apart the WRX wiring loom - I have it ...   Aug 24 2016, 02:05 AM
Old Yella   What did you do with your 914 running gear if I ma...   Aug 24 2016, 02:42 AM
barrym   The motor went to far north Australia - I still ha...   Aug 24 2016, 04:18 AM
barrym   Because I'm switching to electronic throttle o...   Sep 5 2016, 02:35 AM
barrym   been doing a little work on the throttle body - wa...   Sep 9 2016, 05:20 PM
barrym   i'll also add that you have to fool the coroll...   Sep 9 2016, 06:32 PM
barrym   hmm - slight change in plans for the TPS to the Su...   Sep 11 2016, 01:34 AM
barrym   they say that pictures are worth a thousand words ...   Oct 11 2016, 04:54 AM
barrym   and if all this didn't keep me busy i'm in...   Oct 11 2016, 04:56 AM
Cairo94507   Nice progress and work. Congratulations and keep ...   Oct 11 2016, 07:27 AM
jd74914   It looks great Barry! That Corolla pedal is e...   Oct 11 2016, 09:17 AM
barrym   Thanks ! The pedal actually from an '07 Ca...   Oct 11 2016, 04:23 PM
jd74914   Cool! Thanks for the info! I really like t...   Oct 14 2016, 07:37 AM
barrym   sure - i'm pretty sure this is the final xls I...   Oct 14 2016, 08:05 PM
- Lo-Fi Version Time is now: 1st July 2025 - 06:58 AM
