| theleschyouknow |
Nov 12 2014, 04:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 524 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None |
I understand how to get the best defrost cuz it tells me right there on the control panel but how do set the sliders for best cabin heat?
what does each slider control? what do the three blue icons in the middle (| || |||) designate? tried search here and looking at manual fixin to ask google but thought I'd ask the collective too tia cjl |
| theleschyouknow |
Nov 12 2014, 04:38 PM
shoulda looked a little harder found it on pelican via mr google
next question bout how long does it take to warm up? my ~20 minute commute doesn't seem to generate much heat cjl |
| BeatNavy |
Nov 12 2014, 05:05 PM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
shoulda looked a little harder found it on pelican via mr google next question bout how long does it take to warm up? my ~20 minute commute doesn't seem to generate much heat cjl You're in Texas! You don't need heat a car with heat! (IMG:style_emoticons/default/smile.gif) Does your engine compartment heater blower fan work and is it coming on when you pull the lever? Is the rest of the heater system in place? Even if it's working optimally it's not going to crank out that much heat. You should feel a difference easily after 20 minutes, but don't expect it to blast out like a furnace, and don't expect the fan to move THAT much air. |
| rgalla9146 |
Nov 12 2014, 05:10 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
shoulda looked a little harder found it on pelican via mr google next question bout how long does it take to warm up? my ~20 minute commute doesn't seem to generate much heat cjl You're in Texas! You don't need heat a car with heat! (IMG:style_emoticons/default/smile.gif) Does your engine compartment heater blower fan work and is it coming on when you pull the lever? Is the rest of the heater system in place? Even if it's working optimally it's not going to crank out that much heat. You should feel a difference easily after 20 minutes, but don't expect it to blast out like a furnace, and don't expect the fan to move THAT much air. Even the engineers at Porsche can explain it. They shot the guy who designed it |
theleschyouknow what's it all mean Nov 12 2014, 04:31 PM
theleschyouknow thanks for the reply yep I know it works (or worke... Nov 12 2014, 05:17 PM
BeatNavy
thanks for the reply yep I know it works (or work... Nov 12 2014, 05:26 PM
The Cabinetmaker The fan can push a lot air and blast your ass too.... Nov 12 2014, 05:26 PM
SirAndy The fan can push a lot air and blast your ass too.... Nov 12 2014, 05:48 PM
BeatNavy
The fan can push a lot air and blast your ass too... Nov 12 2014, 06:58 PM
76-914 First off, in TX it does occasionally get colder t... Nov 12 2014, 05:43 PM
mepstein My car starts getting warm in a couple minutes and... Nov 12 2014, 07:48 PM
Big Len
My car starts getting warm in a couple minutes an... Nov 12 2014, 08:54 PM
Big Len Whoops.Double post Nov 12 2014, 08:54 PM
bigkensteele Somebody correct me if I am wrong, but I believe t... Nov 12 2014, 08:56 PM
pilothyer My heaters in all my cars put out so much heat tha... Nov 12 2014, 09:36 PM
theleschyouknow thanks for all the info I do get heat but it defin... Nov 13 2014, 11:16 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:20 PM |
