> 2056 L - Jet Build advise request
pnewman
post Nov 12 2014, 06:26 PM
Time to rebuild my stock 1.8 L Jet
Keeping the L Jet.
Any recommendations with the 2056 build in regards to the L Jet
-such as cam choice and source etc.
-do's / don'ts from your experience.
-links to like build threads.
Thanks in advance.
r_towle
post Nov 13 2014, 10:15 PM
Custom Member
What is the difference is head flow between the stock heads and the RS heads?
Curious how much change is occurring....
Jake Raby
post Nov 13 2014, 10:59 PM
Engine Surgeon
QUOTE(r_towle @ Nov 13 2014, 08:15 PM) *
On a 2056, about 15HP worth of difference back to back.
On the flow bench the peak flow is very similar, but where the flow peaks at is different and low lift flow and chamber filling is dramatically increased.
The biggest difference is the altered port flow margins between intake and exhaust ports. Remember, peak flow mans a lot less than where the flow is made and what intake : exhaust flow margins are.
These port flow margins work really well with the split duration cams that I developed as part of many engine combinations.
Here's a graph that was handy from the 2006 offerings, the RS is more refined now than this, but this is the general idea. Remember, this is dry flow data and doesn't show swirl, or tumble, or port velocity. But we have all that data as well.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.aircooledtechnology.com-1095-1415941456.1.jpg)
This post has been edited by Jake Raby: Nov 13 2014, 11:04 PM
HAM Inc
post Nov 14 2014, 03:31 PM
QUOTE(Jake Raby @ Nov 13 2014, 09:59 PM) *
That's flow data from two generations ago. We blew past that a while ago. We no longer put flow data out for public consumption, but let's just say that the current version of the RS+ is substantially more potent. That data was from the transition version when the RS+ superseded the LE-180.
Here's a link to our facebook page with pics of the latest RS+
https://www.facebook.com/HoffmanAutomotiveMachine?ref=br_rs
Our latest heads with the upgraded cam offerings will make for an even stouter power-plant than even just a few years ago.
pnewman   2056 L - Jet Build advise request   Nov 12 2014, 06:26 PM
914Sixer   Go to Jake Raby's store. Type4store.com   Nov 12 2014, 07:12 PM
Jake Raby   Go to Jake Raby's store. Type4store.com It...   Nov 13 2014, 12:47 AM
Bleyseng   96mm P&C's New Ham Heads with 42x36 valves...   Nov 13 2014, 09:15 AM
pnewman   96mm P&C's New Ham Heads with 42x36 valve...   Nov 13 2014, 12:53 PM
Racer Chris   Was wondering if 9590 was too aggressive for the ...   Nov 13 2014, 03:32 PM
pnewman   [quote name='pnewman' post='2110062' date='Nov 13...   Nov 13 2014, 05:53 PM
Olympic 1.7   96mm P&C's New Ham Heads with 42x36 valve...   Nov 13 2014, 06:44 PM
r_towle   96mm P&C's New Ham Heads with 42x36 valv...   Nov 13 2014, 11:17 PM
pilothyer   Try to get a 86 - 91 Vanagon 2.1 Liter throttle va...   Nov 13 2014, 07:35 PM
pilothyer   No hijack intended, but what happened to the Raby ...   Nov 13 2014, 08:52 PM
malcolm2   No hijack intended, but what happened to the Raby...   Nov 13 2014, 09:48 PM
eyesright   No hijack intended, but what happened to the Rab...   Nov 14 2014, 08:38 AM
Jake Raby   [quote name='malcolm2' post='2110239' date='Nov 1...   Nov 14 2014, 09:11 AM
malcolm2   No hijack intended, but what happened to the Raby...   Nov 13 2014, 09:49 PM
Jake Raby   No hijack intended, but what happened to the Raby...   Nov 13 2014, 10:07 PM
r_towle   What is the difference is head flow between the st...   Nov 13 2014, 10:15 PM
Jake Raby   What is the difference is head flow between the s...   Nov 13 2014, 10:59 PM
r_towle   What is the difference is head flow between the ...   Nov 13 2014, 11:04 PM
HAM Inc   [quote name='r_towle' post='2110262' date='Nov 13...   Nov 14 2014, 03:31 PM
Jake Raby   This is the head that was developed to work with L...   Nov 13 2014, 11:13 PM
r_towle   Cool. one of the other poster said he built an eng...   Nov 13 2014, 11:16 PM
Olympic 1.7   Cool. one of the other poster said he built an en...   Nov 14 2014, 09:26 PM
Jake Raby   9590+RS Plus & 8.5:1 with tight deck will make...   Nov 13 2014, 11:26 PM
Olympic 1.7   Damn, don't know why the picture did that..???...   Nov 14 2014, 09:29 PM
- Lo-Fi Version Time is now: 11th November 2026 - 03:06 AM
