4 lug billet hub adapters?, vented rotors |
zach914v8 |
Nov 16 2014, 12:29 AM
Member Group: Members Posts: 216 Joined: 26-November 10 From: Houston Member No.: 12,426 Region Association: Southwest Region |
Some years ago I read that brad Roberts was building these hubs that would allow us 4 lug guys the chance to use vented rotors. Apparently for some reason they can't be found anywhere. I have invested $$$ in aftermarket wheels and want to stay with 4 lugs.
Does anyone here have any information about these hubs? Maybe drawings or something, so I can have a set machined. Thanks Zach |
white1975 |
Nov 17 2014, 12:55 AM
Member Group: Members Posts: 94 Joined: 28-December 10 From: Milford ohio Member No.: 12,529 Region Association: None |
(IMG:style_emoticons/default/piratenanner.gif) I have a friend that has a machine shop that is more for play and spare after hours work that should cut down on cost plus I need a set too 5 lug setup
which means he will have me out there helping just need a copy of them to go at it |
stugray |
Nov 17 2014, 10:31 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
(IMG:style_emoticons/default/piratenanner.gif) I have a friend that has a machine shop that is more for play and spare after hours work that should cut down on cost plus I need a set too 5 lug setup which means he will have me out there helping just need a copy of them to go at it If the design was done smart, you could make these hubs, and then drill them for 4 or 5 lug wheels. The "core" would be indentical, then the holes drilled for whichever wheel you wanted. |
Lo-Fi Version | Time is now: 7th June 2024 - 08:23 PM |
