zach914v8 |
Member ![]() ![]() Group: Members Posts: 216 Joined: 26-November 10 From: Houston Member No.: 12,426 Region Association: Southwest Region ![]() |
Some years ago I read that brad Roberts was building these hubs that would allow us 4 lug guys the chance to use vented rotors. Apparently for some reason they can't be found anywhere. I have invested $$$ in aftermarket wheels and want to stay with 4 lugs.
Does anyone here have any information about these hubs? Maybe drawings or something, so I can have a set machined. Thanks Zach |
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
I see that site also has 5 lug variety ! Vented . So would those work with stock calipers? I did the 5 lug conversion using the 4 lug drilled to 5 by Eric shea. So if I wanted to step up to have vented rotors these would work on my front with current set up?- I'm referring to the German ones (IMG:style_emoticons/default/smile.gif)
Attached image(s) ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,541 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I see that site also has 5 lug variety ! Vented . So would those work with stock calipers? I did the 5 lug conversion using the 4 lug drilled to 5 by Eric shea. So if I wanted to step up to have vented rotors these would work on my front with current set up?- I'm referring to the German ones (IMG:style_emoticons/default/smile.gif) Not with stock calpiers. 911 M calipers or Alfa calipers would work. Or a 1978 BMW 320 I caliper. Might need the pad machined. They used vented rotors for 1 year only. |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
I see that site also has 5 lug variety ! Vented . So would those work with stock calipers? I did the 5 lug conversion using the 4 lug drilled to 5 by Eric shea. So if I wanted to step up to have vented rotors these would work on my front with current set up?- I'm referring to the German ones (IMG:style_emoticons/default/smile.gif) Not with stock calpiers. 911 M calipers or Alfa calipers would work. Or a 1978 BMW 320 I caliper. Might need the pad machined. They used vented rotors for 1 year only. Man I am rusty with this stuff these days....what rotors worked with the vented and non-vented Volvo 240 calipers? |
Lo-Fi Version | Time is now: 15th June 2024 - 09:39 AM |
