4 lug billet hub adapters?, vented rotors |
zach914v8 |
Nov 16 2014, 12:29 AM
Member Group: Members Posts: 216 Joined: 26-November 10 From: Houston Member No.: 12,426 Region Association: Southwest Region |
Some years ago I read that brad Roberts was building these hubs that would allow us 4 lug guys the chance to use vented rotors. Apparently for some reason they can't be found anywhere. I have invested $$$ in aftermarket wheels and want to stay with 4 lugs.
Does anyone here have any information about these hubs? Maybe drawings or something, so I can have a set machined. Thanks Zach |
DRPHIL914 |
Nov 17 2014, 09:49 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I see that site also has 5 lug variety ! Vented . So would those work with stock calipers? I did the 5 lug conversion using the 4 lug drilled to 5 by Eric shea. So if I wanted to step up to have vented rotors these would work on my front with current set up?- I'm referring to the German ones (IMG:style_emoticons/default/smile.gif)
Attached image(s) |
Starlack |
Nov 18 2014, 05:49 AM
Member Group: Members Posts: 67 Joined: 8-January 12 From: Germany Member No.: 13,978 Region Association: None |
I see that site also has 5 lug variety ! Vented . So would those work with stock calipers? I did the 5 lug conversion using the 4 lug drilled to 5 by Eric shea. So if I wanted to step up to have vented rotors these would work on my front with current set up?- I'm referring to the German ones (IMG:style_emoticons/default/smile.gif) Yes you can installed this brake vented discs on the 914er with 5Lug Am I doing now. You see here. Kerscher Break disc 4 Lug with Brake Calipers from the 911 . The hole spacing by the Caliper is 76mm On Thursday this Week build the parts in my 14er one then I know more. All you need is the calipers from the 911 or BMW 320i You understand me? |
DRPHIL914 |
Nov 18 2014, 07:06 AM
I see that site also has 5 lug variety ! Vented . So would those work with stock calipers? I did the 5 lug conversion using the 4 lug drilled to 5 by Eric shea. So if I wanted to step up to have vented rotors these would work on my front with current set up?- I'm referring to the German ones (IMG:style_emoticons/default/smile.gif) Yes you can installed this brake vented discs on the 914er with 5Lug Am I doing now. You see here. Kerscher Break disc 4 Lug with Brake Calipers from the 911 . The hole spacing by the Caliper is 76mm On Thursday this Week build the parts in my 14er one then I know more. All you need is the calipers from the 911 or BMW 320i You understand me? Yes, but 76mm is = to 2.995 or 3 inches which is the bolt spacing for a 914, a 911 is 3.5" so this should work for stock those in your picture look like stock callipers for 914 from Eric Shea of PMB performance ini Sandy, Utah correct? -thanks for sharing the link and giving some great information from Germany!! also share some pictures when you get a chance as you are completing your project! Phil Wagner |
Lo-Fi Version | Time is now: 7th June 2024 - 07:19 PM |
