To blast or not to blast?, Striping chassis for repair. |
914GTSTI |
Nov 22 2012, 09:51 AM
Member Group: Members Posts: 270 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
Who has stripped their chassie and had it blasted? The good and the bad. And what did you do to the metal after it was striped? My car will be on a rotisserie for the stripping.
Thanks! |
scotty b |
Nov 22 2012, 07:21 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Dipping = I have no personal experience so I wont comment
Soda = does a good job on paint but does nothing to the rust, bondo, lead etc. Leaves a residue that must be dealt with properly. This has become less of an issue in the last few years. The guy that comes to you ( how I had it done ) Isn't cheap, but neither is his setup. We had a Healy done, exterior only, and he charged us 1800.00 "sand" = It does a great job when the user knows what the hell he is doing. If he doesnt he can severly damage the car.Makes a big mess,it does leave ALOT of grit that will be coming out for years, and for me the finish is a bit rougher then I like, but it gets it all off. Would take me the better part of a day to do a small car, goes through a lot of sand dry ice = I have no idea dustless blasting = this is the system I now have after getting tired of the results with " sand " this setup uses a slurry of water and crushed glass ( recycled bottles ). There is no dust created so it takes minimal room. WILL NOT damage the metal. I have held this thing wide open 2" off of a decklid and couldn't warp it. The water washes MOST of the media off as you are blasting. It uses a chemical called HOLD TITE that is well known in the marine industry to prevent flash rust for up to 72 hours. Works quicker than my old pressure pot using sand, does a great job on paint, rust, bondo slows it down a little but it still does a good job on it. The setup is expensive,it requires a seperate tow behind compressor, if it sits more than 72 hours without being primed it definitely will need some touch up as the flash rust comes on quickly. The slurry does get packed into corners and crevices and doesn't rinse out all that easily. Goes through a fair amount of media sanding = takes forever, makes a HUGE mess,2nd cheapest of all options if you do it yourself torch and scraper = quiet, cheap, clean. Takes a long time, doesn't get into tight spots very well. Easy to warp the metal if you're not careful chemical strip = caustic, messy, not cheap when you add up all the cans you will go through, PITA to neutralize and clean up after, doesnt get the tight spots well They all have their ups and downs. IMHO...Go for what you can afford, just make sure the stripper knows what they are doing |
buck toenges |
Nov 18 2014, 07:05 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
Dipping = I have no personal experience so I wont comment Soda = does a good job on paint but does nothing to the rust, bondo, lead etc. Leaves a residue that must be dealt with properly. This has become less of an issue in the last few years. The guy that comes to you ( how I had it done ) Isn't cheap, but neither is his setup. We had a Healy done, exterior only, and he charged us 1800.00 "sand" = It does a great job when the user knows what the hell he is doing. If he doesnt he can severly damage the car.Makes a big mess,it does leave ALOT of grit that will be coming out for years, and for me the finish is a bit rougher then I like, but it gets it all off. Would take me the better part of a day to do a small car, goes through a lot of sand dry ice = I have no idea dustless blasting = this is the system I now have after getting tired of the results with " sand " this setup uses a slurry of water and crushed glass ( recycled bottles ). There is no dust created so it takes minimal room. WILL NOT damage the metal. I have held this thing wide open 2" off of a decklid and couldn't warp it. The water washes MOST of the media off as you are blasting. It uses a chemical called HOLD TITE that is well known in the marine industry to prevent flash rust for up to 72 hours. Works quicker than my old pressure pot using sand, does a great job on paint, rust, bondo slows it down a little but it still does a good job on it. The setup is expensive,it requires a seperate tow behind compressor, if it sits more than 72 hours without being primed it definitely will need some touch up as the flash rust comes on quickly. The slurry does get packed into corners and crevices and doesn't rinse out all that easily. Goes through a fair amount of media sanding = takes forever, makes a HUGE mess,2nd cheapest of all options if you do it yourself torch and scraper = quiet, cheap, clean. Takes a long time, doesn't get into tight spots very well. Easy to warp the metal if you're not careful chemical strip = caustic, messy, not cheap when you add up all the cans you will go through, PITA to neutralize and clean up after, doesnt get the tight spots well They all have their ups and downs. IMHO...Go for what you can afford, just make sure the stripper knows what they are doing How is the dustless blasting system working out for you? All video I have seen was blasting the outside of a car. How is it for the inside? Are you having a problem cleaning out the slurry on the inside of the car? How about the inside of the doors? No problem with flash rust? |
Lo-Fi Version | Time is now: 6th June 2024 - 02:46 PM |
