> To blast or not to blast?, Striping chassis for repair.
914GTSTI
post Nov 22 2012, 09:51 AM
Who has stripped their chassie and had it blasted? The good and the bad. And what did you do to the metal after it was striped? My car will be on a rotisserie for the stripping.
Thanks!
boxsterfan
post Nov 18 2014, 10:09 PM
914's are kewl
If you have all the bolts out of the car and it is on a rotisserie, then you really should get inside the longs (cut them open) and also take off the floor pans (lots of rust on the seams). You came this far....might as well go the extra steps.
OllieG
post Nov 19 2014, 02:09 AM
OllieG
Region Association: England
QUOTE(boxsterfan @ Nov 19 2014, 04:09 AM) *
Really??…take off the floorpans? That is a BIG job especially if you're not a pro - removing them really carefully so they can go back on 'easily' and neatly. Sure, replace them if they are shot, but surely not necessary if they're in 'good' shape?
There's probably going to be varying degrees of rust in every little seam but you can't take the entire car apart...
914GTSTI   To blast or not to blast?   Nov 22 2012, 09:51 AM
GeorgeRud   Seems that blasting would be the quickest and easi...   Nov 22 2012, 11:53 AM
gopack   I had mine soda blasted, did a good job of taking ...   Nov 22 2012, 11:58 AM
Gint   My /6 tub was dipped. The tub was painted and it...   Nov 22 2012, 12:01 PM
Eric_Shea   My /6 tub was dipped. The tub was painted and it...   Nov 22 2012, 04:11 PM
biosurfer1   5 years? you need to get working on that!...   Nov 22 2012, 12:38 PM
cary   I'd say it depends on your budget. Dipping is...   Nov 22 2012, 01:07 PM
wingnut86   Many of the blasters down South provide an option ...   Nov 22 2012, 01:28 PM
turk22   The dude in Italy had his car put in a kiln/oven a...   Nov 22 2012, 03:11 PM
SirAndy   Who has stripped their chassie and had it blasted...   Nov 22 2012, 04:04 PM
Gint   That's why I paid the big money having it fini...   Nov 22 2012, 04:13 PM
BarberDave   :trophy: Has anybody had experence with Dry...   Nov 22 2012, 04:50 PM
pcar916   Just had mine fine-grit glass-beaded ($800). ...   Nov 22 2012, 06:49 PM
scotty b   Dipping = I have no personal experience so I wont ...   Nov 22 2012, 07:21 PM
MDG   IMHO...Go for what you can afford, just make sur...   Nov 22 2012, 07:30 PM
914GTSTI   IMHO...Go for what you can afford, just make su...   Nov 22 2012, 09:09 PM
scotty b   [quote name='MDG' post='1772289' date='Nov 22 201...   Nov 22 2012, 09:15 PM
buck toenges   Dipping = I have no personal experience so I wont...   Nov 18 2014, 07:05 PM
Cairo94507   I am pretty sure Scotty B will stripping my Six in...   Nov 23 2012, 09:06 AM
cary   Another new method is wet sand blasting. Its done ...   Nov 23 2012, 10:22 AM
Eric_Shea   I saw that at SEMA. You must have a rust agent to...   Nov 23 2012, 01:44 PM
914GTSTI   OK,so I went to HF and R2 came home with me! T...   Nov 24 2012, 04:40 PM
cary   Looks nice. Good work ....................   Nov 24 2012, 05:36 PM
rdauenhauer   My experience: 1) had the LE blasted with Sand ...   Nov 24 2012, 08:01 PM
914GTSTI   My experience: 1) had the LE blasted with Sand ...   Nov 24 2012, 08:14 PM
boxsterfan   If you have all the bolts out of the car and it is...   Nov 18 2014, 10:09 PM
OllieG   If you have all the bolts out of the car and it i...   Nov 19 2014, 02:09 AM
cary   I think this is the system that Scotty has. http:/...   Nov 19 2014, 08:57 PM
mepstein   I think this is the system that Scotty has. http:...   Nov 19 2014, 09:01 PM
cary   I know. That's another $3-$4k. So no...   Nov 19 2014, 09:37 PM
scotty b   Yes you need a large diesel 185 CFM unit to run th...   Nov 20 2014, 07:17 AM
- Lo-Fi Version Time is now: 21st September 2026 - 11:01 AM
