| siverson |
Nov 18 2014, 12:47 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,464 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California
$63:
http://www.patrickmotorsports.com/part/throttle-cable-914-6/ $103: http://www.pelicanparts.com/catalog/SuperC...E_pg1.htm#item0 Any other options? Anyone use the PM cable? -Steve |
| patssle |
Nov 18 2014, 09:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
| eyesright |
Nov 19 2014, 09:22 AM
Member ![]() ![]() Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
Yup! I bought all the bellcrank paraphenelia, being my first -6 conversion. When I installed it I was amazed at how rinky-dink the set up was. When they designed the 914 they obviously turned the 911 set up around, instead of just running the cable thru the sheet metal and connecting directly to the carbs. Must have put some of Ferry's summer intern nephews on to the task. And the later -4 914's don't have the transmission boss drilled out to accept the bellcrank shaft. Anyway, I made a similar bracket and encourage anybody to try it. A -4 cable is less expensive and can be made to work as above, it just doesn't have a threaded end. If I had an original I'd probably stick with the stock set up but... Nice photo. Here's mine. Not quite as purdy as yours but it works. Somebody could build a few of these and sell them to the rest of us for $30 but its easy to do. Go for it, guys! |
siverson 914-6 throttle cables Nov 18 2014, 12:47 PM
Mark Henry Is it a /6 or a conversion?
I need to do this on m... Nov 18 2014, 01:32 PM
siverson I'm shopping for my original 914-6 now.
On my... Nov 18 2014, 01:42 PM
Krieger I have been using the PM for more than a year most... Nov 18 2014, 01:44 PM
Joe Sharp Only part that I don't from Pelican. It's ... Nov 18 2014, 02:32 PM
Brian_Boss The Patrick cable sure looks like a Terry Cable to... Nov 18 2014, 03:26 PM
SLITS I just called Terry Cable and had them make me a ... Nov 19 2014, 07:19 AM
naro914 You can just buy a /6 cable from Terry cable...sto... Nov 19 2014, 05:46 PM
siverson > You can just buy a /6 cable from Terry cable
... Nov 20 2014, 12:27 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 11:38 PM |
