| JawjaPorsche |
Jan 16 2012, 04:55 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I see where the Tapered Fuel Hose is no longer available at Pelican Parts:
http://www.pelicanparts.com/cgi-bin/smart/...74%29%2C%20Each Does anyone know an alternative source? Also dumb question. The description says "Tapered Fuel Hose For Connection at Fuel Filter." I thought the hose was also used for the outlet port on the fuel pump because the connection is smaller than the standard hose size: 8 mm? |
| dcheek |
Nov 19 2014, 03:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 30-May 06 From: Westfield, New Jersey Member No.: 6,103 |
This is the one I used on my Rabbit a while back. It looks a little shorter and you would have to confirm the diameters. It might be worth a look:
http://www.ebay.com/itm/like/351224921678?lpid=82 Dave |
JawjaPorsche Tapered Fuel Hose Jan 16 2012, 04:55 PM
billh1963 I thought it was only for the fuel tank line comin... Jan 16 2012, 05:12 PM
wingnut86 Check Automation and Vertex.
They used to carry t... Jan 16 2012, 05:50 PM
type47 Chris Foley sells a stainless steel piece that doe... Jan 16 2012, 06:12 PM
Racer Chris
Chris Foley sells a stainless steel piece that do... Jan 16 2012, 06:42 PM
SLITS Gad, go to ACE Hardware or a place like that and g... Jan 16 2012, 06:47 PM
Cap'n Krusty
Gad, go to ACE Hardware or a place like that and ... Jan 16 2012, 08:19 PM
SLITS
Gad, go to ACE Hardware or a place like that and... Jan 17 2012, 10:23 AM
dangrouche I employ Chris' taper stainless adaptor tubing... Jan 16 2012, 07:46 PM
rick 918-S
I employ Chris' taper stainless adaptor tubin... Jan 17 2012, 12:03 AM
ClayPerrine If IIRC, there is a Mercedes Diesel hose that wor... Jan 17 2012, 10:30 AM
Phoenix914
If IIRC, there is a Mercedes Diesel hose that wo... Aug 5 2014, 11:12 AM
Dave_Darling Your hardware store will have hose barbs and fitti... Aug 5 2014, 01:27 PM
Phoenix914 Thanks Dave. I'll probably go that route.
Th... Aug 5 2014, 01:34 PM
pete000 Glad I got one a few years back when I started my ... Aug 5 2014, 02:16 PM
Phoenix914
good grief I need to get my car going again ... Aug 5 2014, 02:39 PM
bdstone914
good grief I need to get my car going again ... Aug 5 2014, 06:58 PM
Phoenix914
I made one out of a piece of hose that was the co... Aug 5 2014, 07:24 PM
Racer Chris Trying to find that tapered hose is a waste of tim... Aug 5 2014, 03:14 PM
mepstein I bought mine from Chris - Tangerine. He has all t... Aug 5 2014, 08:06 PM
pete000 I noticed Sierra Madre lists them as NLA now too..... Aug 6 2014, 11:18 PM
Phoenix914 That looks like a nice piece, and cheaper than a M... Aug 7 2014, 05:09 AM
Racer Chris That Jegs piece is perfect. Aug 7 2014, 06:16 AM
Phoenix914
Looks like it might... Aug 7 2014, 06:22 AM
Racer Chris
Looks like it migh... Aug 7 2014, 07:45 AM
stinkindiesel Has anybody identified a suitable fuel filter with... Aug 19 2014, 03:45 PM
Kansas 914
Has anybody identified a suitable fuel filter wit... Aug 19 2014, 07:51 PM
stinkindiesel
I used to buy mine from Brad at 914ltd.com. He do... Aug 20 2014, 07:47 AM
Racer Chris
Yep, the WIX 33274 is the correct one that has th... Aug 20 2014, 08:30 AM
stinkindiesel
Yep, the WIX 33274 is the correct one that has t... Aug 20 2014, 12:22 PM
Dave_Darling
Has anybody identified a suitable fuel filter wit... Aug 19 2014, 09:09 PM
pete000 Fram makes an all metal filter with the 3/8 (10mm)... Aug 19 2014, 09:07 PM
mapguy Awesome!
That Wix unit is just the ticket... Aug 19 2014, 11:01 PM
bandjoey Bought one like the wix. Don't remember the br... Aug 20 2014, 07:55 AM
Phoenix914 Has anybody used this WIX filter? The description... Nov 18 2014, 10:06 AM
Racer Chris
Has anybody used this WIX filter? The descriptio... Nov 18 2014, 11:25 AM
Phoenix914
Wix 33002 is a better choice. 8mm inlet and outl... Nov 18 2014, 01:15 PM
dcheek VW uses a similar hose. I ordered one for one of m... Nov 18 2014, 02:34 PM
Mikey914 I personally don't like Wix. I had a problem w... Nov 18 2014, 11:59 PM
Phoenix914 This listing says the hose is 7/11 mm. :idea:
... Nov 19 2014, 04:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:05 AM |
