> Where do you find these gaskets?
cary
post Jul 20 2014, 08:52 AM
I pulled the engine to replace the oil pump cover .... drip, drip, drip.
But this gasket came apart when I pulled the heater tin.
It goes inside heater tin that attaches to blower housing. #24. Keeps moisture from getting inside the heating system I assume.
Dug thru both AA and Pelican and found nothing. Made an attempt at Bus Depot but I have no idea what its called or the part number. I know that I replaced them around 7-8 years ago.
cary
post Nov 20 2014, 02:49 PM
Mark do you need a couple for making patterns?
cary   Where do you find these gaskets?   Jul 20 2014, 08:52 AM
injunmort   try 914rubber, vendor on this site   Jul 20 2014, 09:26 AM
type47   I think what you're looking for is called a ...   Jul 20 2014, 09:35 AM
barefoot   My tins are missing these gaskets. Rather than pa...   Jul 20 2014, 09:55 AM
larryM   hardware store - std household door seals - glue ...   Jul 20 2014, 09:34 PM
bdstone914   hardware store - std household door seals - glue ...   Jul 21 2014, 12:49 PM
teenerteck   I don't think the heat will be an issue consid...   Jul 21 2014, 09:37 PM
cary   Here's the closest thing I've found. http:...   Jul 21 2014, 10:38 PM
rhodyguy   make an RTV bead where the gasket would lay on the...   Jul 22 2014, 08:14 AM
saigon71   I made some with thick cork gasket material from F...   Jul 23 2014, 06:34 AM
cary   Here's what I finally did. It's been curin...   Sep 21 2014, 09:45 AM
Bartlett 914   I used an O-ring I had around. It sealed both top ...   Sep 21 2014, 10:20 AM
pilothyer   I bought one of those red silicone flexible baking...   Sep 21 2014, 10:44 AM
Mikey914   Pretty easy to make. And pretty cheap too. If you ...   Sep 21 2014, 10:52 AM
bdstone914   Pretty easy to make. And pretty cheap too. If you...   Sep 21 2014, 10:59 AM
porsche913b_sp   Pretty easy to make. And pretty cheap too. If you...   Nov 18 2014, 10:52 PM
Larmo63   914s have heaters? :blink:   Sep 21 2014, 01:07 PM
bandjoey   anyone making these? couldn't find them on 91...   Nov 18 2014, 03:15 PM
rhodyguy   What crap! $33.85 for one side and ...   Nov 18 2014, 05:54 PM
mapguy   I would also be interested in a set, provided I ca...   Nov 18 2014, 11:30 PM
Mikey914   I need to make templates for these still. other th...   Nov 19 2014, 12:51 AM
walterolin   I need two sets. And I got my grill badges, the...   Nov 19 2014, 07:11 AM
BeatNavy   Yes, Mark, that would be swell to have these avail...   Nov 19 2014, 07:50 AM
cary   Mark do you need a couple for making patterns?   Nov 20 2014, 02:49 PM
- Lo-Fi Version Time is now: 7th December 2025 - 05:58 PM
