| rtalich |
Nov 9 2014, 10:46 AM
Member ![]() ![]() Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
Found a big block of foam and thought I would see about making my own center console. Here's the progress so far. This will be my first project using fiberglass... any pointers or advice? Should I use cloth or mat? Should I paint or use color resin?
Thanks Rob Attached thumbnail(s) |
| 914Sixer |
Nov 22 2014, 05:20 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,453 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
What about using the heat shrink type material used on model airplanes for a covering?
rtalich Interior remodeling Nov 9 2014, 10:46 AM
McMark Mat will work fine. Don't try to do it all in... Nov 9 2014, 10:53 AM
McMark Oh and you might as well stick a 6.5" subwoof... Nov 9 2014, 10:55 AM
rtalich Thanks Mark! If I used cloth and then a few co... Nov 9 2014, 12:03 PM
PanelBilly Wrap it in vinyl and make an upholstered cap Nov 9 2014, 12:12 PM
porschefile2010 Interesting job ahead of you. Regardless of what y... Nov 9 2014, 12:19 PM
Bob L. How are you going to Handle the hole for the shift... Nov 9 2014, 12:27 PM
veekry9 http://www.fiero.nl/forum/Forum3/HTML/000091-53.ht... Nov 9 2014, 04:45 PM
barefoot
Recommend using epoxy. I've used quite a bi... Nov 10 2014, 11:41 AM
rtalich
How are you going to Handle the hole for the shif... Nov 9 2014, 06:01 PM
McMark Just plan on using bondo, cause it's gonna hap... Nov 9 2014, 06:39 PM
CptTripps Very cool. Where can I buy some of this foam? That... Nov 10 2014, 12:56 PM
altitude411
Very cool. Where can I buy some of this foam? Tha... Nov 11 2014, 07:59 PM
veekry9 http://www.freemansupply.com/
http://www.freemans... Nov 10 2014, 01:34 PM
rtalich Thanks for all the suggestions so far!! At... Nov 10 2014, 02:31 PM
ThePaintedMan
Thanks for all the suggestions so far!! A... Nov 11 2014, 08:08 PM
porschefile2010 And for a first time amateur build I really think ... Nov 12 2014, 12:19 PM
barefoot
And for a first time amateur build I really think... Nov 12 2014, 05:08 PM
rtalich A bit more progress. Nov 11 2014, 06:34 PM
rtalich Thanks!!! I will follow the steps and ... Nov 12 2014, 12:33 PM
McMark Consider some access to adjust the shifter. If yo... Nov 12 2014, 12:50 PM
G e o r g e are you going to incorporate a spot for the SDS co... Nov 12 2014, 02:00 PM
rtalich
are you going to incorporate a spot for the SDS c... Nov 12 2014, 02:08 PM
914bub
Although I may not... probably going to be switc... Nov 22 2014, 07:27 PM
veekry9 http://www.fisheriessupply.com/resins-and-...ies/e... Nov 12 2014, 02:23 PM
76-914
http://www.fisheriessupply.com/resins-and-...ies/... Nov 22 2014, 08:13 PM
rtalich Some progress. I brushed on a few coats of white w... Nov 21 2014, 05:13 PM
rtalich Before: Nov 21 2014, 05:13 PM
rtalich After: Nov 21 2014, 05:14 PM
rtalich One more. Ready for glass. I am leaning toward co... Nov 21 2014, 05:19 PM
Andyrew Very nice! Thats almost marketable! Nov 21 2014, 05:57 PM
scotty b
:ag... Nov 21 2014, 06:14 PM
Chris914n6 Did you compensate for the thickness of the glass/... Nov 21 2014, 06:35 PM
rtalich
[qu... Nov 22 2014, 01:05 PM
rtalich
What about using the heat shrink type material us... Nov 22 2014, 07:00 PM
altitude411
[quote name='914Sixer' post='2113665' date='Nov 2... Nov 22 2014, 08:57 PM
914Sixer No link but Google is probably able to help find t... Nov 22 2014, 07:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:09 PM |
