| McMark |
Oct 12 2014, 02:16 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
I've been collecting parts for my conversion and I just got my 911 ignition switch (P/N 911.613.011.01). It's got the correct silver center. I have an original 914/6 steering column, but the steering lock arm doesn't fit into the bracket into the column. I know this is a 'normal' thing and removing some material will make everything work fine. But since I'm mostly insane, I'd like to see pics of a real 914/6 ignition switch to compare and replicate if possible.
Anyone have pictures? Even better, anyone have one they can measure? And what about the original unit part number? What's that? The number in the PET doesn't seem to match the numbers I've seen. Attached image(s)
| Harpo |
Nov 27 2014, 11:13 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I have never been sucessful in rekeying a 911 ignition switch. I'm not sure it was ever ment to be rekeyed. Doors, trunks and glove boxes however, have been streight forward.
David |
| John |
Nov 30 2014, 08:19 PM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I have never been sucessful in rekeying a 911 ignition switch. I'm not sure it was ever ment to be rekeyed. Doors, trunks and glove boxes however, have been streight forward. David I did mine. There was a roll pin driven into a blind hole. I had to drill a secondary hole in order to get the roll pin out. After that fiasco, it was straight forward. I started out with the ignition switch and column switches and clamshells from a 1973 911. ![]() ![]() ![]() ![]() ![]() |
McMark 914/6 Ignition Switch Oct 12 2014, 02:16 PM
SirAndy Yepp, i had to shave off some material from the 91... Oct 12 2014, 03:51 PM
SixerJ Hi Mark, does this help?
I bought a complete -6 l... Oct 12 2014, 03:56 PM
SixerJ Last 2 pictures, the last one was a bit difficult ... Oct 12 2014, 04:01 PM
McMark SixerJ, THANKS! Can you take one more with th... Oct 12 2014, 04:08 PM
SixerJ
SixerJ, THANKS! Can you take one more with t... Oct 12 2014, 04:23 PM
sixnotfour they added more material so the bolt actually secu... Oct 12 2014, 07:17 PM
McMark Awesome! Now I can make mine look right.
gri... Oct 12 2014, 09:34 PM
biosurfer1
grind flat, throw away, grind flat, throw away,... Oct 21 2014, 03:40 PM
914Sixer 914-6 PET shows the lock assembly as 911.613.901.0... Oct 12 2014, 09:24 PM
SixerJ Mark,
Apologies for hijacking your thread, but co... Oct 13 2014, 09:09 AM
larryM notwithstanding all the perfection above
- if yo... Oct 16 2014, 09:21 PM
McMark Pictures of the steering column. Let me know what... Oct 21 2014, 12:21 PM
Mark Henry This is a lot of work...wasn't the '72 six... Oct 21 2014, 01:01 PM
This is a lot of work...wasn't the '72 si... Oct 21 2014, 03:34 PM
altitude411 What is this connection for? My '70 six does ... Oct 21 2014, 04:32 PM
type47fan
What is this connection for? My '70 six does... Oct 21 2014, 07:28 PM
McMark
Also does any know of a clamshell vendor or have ... Oct 21 2014, 08:08 PM
altitude411 Ah, that makes sense. Good, I'm glad I don... Oct 21 2014, 07:54 PM
altitude411 Thanks for the heads up Mark, I'll keep shoppi... Oct 21 2014, 08:21 PM
SixerJ Thanks for the pictures, wow, even a NOS sticker, ... Oct 22 2014, 03:50 PM
SirAndy Presumably to make a 6 repro, you would start with... Oct 22 2014, 07:48 PM
SixerJ Great thread, thank you.
It's prompted me to ... Oct 24 2014, 01:16 PM
McMark Got my switch modified by the machine shop. They ... Nov 26 2014, 03:41 PM
SixerJ
Got my switch modified by the machine shop. They... Nov 28 2014, 11:48 AM
I have never been sucessful in rekeying a 911 ig... Nov 30 2014, 08:32 PM
John
[quote name='John' post='2116838' date='Nov 30 20... Dec 4 2014, 09:10 PM
jkb944t Would anyone know where a good place to start to l... Apr 15 2015, 10:35 AM
naro914 I went a different route for the column...I wanted... Apr 15 2015, 02:12 PM
jkb944t If I understand your post correctly you simply rem... Apr 15 2015, 02:47 PM
naro914
I’m not sure what part you were going to sell t... Apr 15 2015, 03:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th November 2025 - 08:44 AM |
