buck toenges |
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None ![]() ![]() |
Here are some pics from my '70 914 that has a newer steering column put in. You will notice that the steering column support has been cut out on the bottom. I have also taken some pics of the joints. What has to be done to make this work? I do think that there is a "clunk" going on as I turn the steering wheel. I think it is the shafts or the joints hitting the dash area but I am not sure.
What is the difference between the newer chassis and older chassis that makes a difference with the steering column? Attached thumbnail(s) ![]() Attached image(s) ![]() ![]() |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
The shafts have to be re-notched. The length and angle is different between the years.
The "clunk" you hear is the u-joints binding and the constant pull you're putting on the rubber steering coupler will result in premature failure of the coupler. I went through all this several years ago when i put a '74 column in my '70 car. (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 12th July 2025 - 04:43 PM |
