| Eric_Shea |
Aug 26 2004, 12:40 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Well... the 914-6 is done. All the rubber, seals, bumpers windows etc. have been put back in. Last task was to clean out and install the gas tank. I used new lines up front and none are pinched etc. The car won't start.
I can't hear the pump. I can usually detect the whine and hear the gurgles in the tank once it starts. I checked the wiring to the pump and it is fine. Does the fuel pump need to be primed after the tank has come out?? Help me with the final step... Thanks! |
| Eric_Shea |
Aug 26 2004, 01:44 PM
Checked the fuses first...
I'll get under there with a Vu Meter (IMG:style_emoticons/default/mad.gif) |
Eric_Shea 914-6 Starting Problems Aug 26 2004, 12:40 PM
lapuwali The fuel pump should make noise even if it needs p... Aug 26 2004, 01:12 PM
seanery It's probably that small motor. I heard those ... Aug 26 2004, 01:14 PM
Eric_Shea I'll bet it's running but I just can't... Aug 26 2004, 01:16 PM
Eric_Shea Pump no workie... I pulled the plug while the key ... Aug 26 2004, 01:34 PM
lapuwali Before I blamed the pump, I'd check for a good... Aug 26 2004, 01:41 PM
Ferg Sounds silly but check your fuses, and has anyone ... Aug 26 2004, 01:42 PM
Eric_Shea OK... There's power to the pump. Still no pum... Aug 27 2004, 10:28 AM
seanery tap it lightly with your 5lb sledge :) Aug 27 2004, 11:19 AM
Eric_Shea Pump's out.
Have I mentioned lately how muc... Aug 27 2004, 12:07 PM
seanery Eric,
why not replace it with a facet? I know it... Aug 27 2004, 12:11 PM
Eric_Shea Because I'm the second caretaker of this car a... Aug 27 2004, 12:39 PM
Eric_Shea Houston... we have ignition.
The little whore jus... Aug 27 2004, 04:26 PM
seanery congrats Eric! Aug 27 2004, 05:30 PM
vortrex same thing happened to me before when my car sat u... Aug 27 2004, 05:39 PM
Eric_Shea Just Posted them... "Fixing the Sixes" Aug 27 2004, 07:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd October 2026 - 02:51 PM |
