| ndfrigi |
Dec 3 2014, 03:34 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
Hi teeners,
I'm planning of buying a 68 912 front and rear suspension. Can I use the strut, hubs, calipers and rotors for a 75 914 for my 5 lug conversion and rear suspension also has the hub, calipers and rotors. Is it the same as early 911 parts? Please give me your usual support/help to a fellow teener. Thanks and God Bless! Noel |
| bdstone914 |
Dec 3 2014, 04:34 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,289 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
You do not want a 68 suspension. That is short wheel base and is a bad choice. The struts are the old style with the different tie rod arm that bolts to the bottom of the strut. Nothing on the rear is usable on a 914. Hubs have a long shaft and a different spline.
ndfrigi Need Opinion fellow teeners Dec 3 2014, 03:34 PM
Mark Henry You have to check if the fronts are solid or vente... Dec 3 2014, 03:58 PM
ndfrigi
You have to check if the fronts are solid or vent... Dec 3 2014, 04:16 PM
Harpo The 68 should have solid rotors because 69 officia... Dec 3 2014, 04:32 PM
roblav1 You can use the steering rack though! They ar... Dec 3 2014, 06:19 PM
914Sixer As Bruce said, leave the 68 suspension alone!... Dec 3 2014, 06:59 PM
ndfrigi Wow that is the best comments/suggestions I got fr... Dec 3 2014, 07:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 01:13 PM |
