> Wanna run vented rotors on the rear?, Wanna have a parking brake, too?
lapuwali
post Aug 26 2004, 12:31 PM
Not another one!
Clay Perrine's solution
Being discussed on the Bird board now. He's prepared to make up 50 sets of the brackets if he can find buyers. The caliper is an off-the-shelf Wilwood part.
lapuwali
post Aug 26 2004, 06:01 PM
Not another one!
One of the problems with using the stock rear calipers is the piston area is too small. This is why, when you run big front brakes, you can use a tee instead of a prop valve. The rears have so little power in relation to the fronts that a prop valve would be fully open, anyway. To get more actual braking force at the rear, you need calipers back there with bigger pistons. Once you do THAT, you (may) need vented rotors back there to handle all of the heat that wasn't generated before, because the rears were doing so little in relation to the fronts. With stock rear calipers, you'd never need vented rotors in back.
lapuwali   Wanna run vented rotors on the rear?   Aug 26 2004, 12:31 PM
GTeener   Did a little research on this subject in June for ...   Aug 26 2004, 12:43 PM
davep   They sure add to the unsprung weight, don't th...   Aug 26 2004, 02:20 PM
rdauenhauer   :angry: Theres gatta be a better way   Aug 26 2004, 05:25 PM
iamchappy   It looks pretty good to me and less work than inst...   Aug 26 2004, 05:38 PM
Andyrew   Tell me whats wrong with putting a spacer in the c...   Aug 26 2004, 05:50 PM
SirAndy   i don't know, seems overkill. i just used the ...   Aug 26 2004, 05:59 PM
lapuwali   One of the problems with using the stock rear cali...   Aug 26 2004, 06:01 PM
lapuwali   How much does that setup run? Do you have to conv...   Aug 26 2004, 06:05 PM
SirAndy   ...   Aug 26 2004, 06:10 PM
Jeroen   I have a set of spaced out stock calipers to work ...   Aug 26 2004, 06:22 PM
lapuwali
  Aug 26 2004, 07:58 PM
SirAndy   ...   Aug 26 2004, 08:15 PM
anthony   Wouldn't you need to stay with 4-lug for certa...   Aug 26 2004, 08:20 PM
SirAndy   <...   Aug 26 2004, 08:31 PM
iamchappy   Sounds like a good winter project for me, I have t...   Aug 26 2004, 09:26 PM
lapuwali   Cause I like the way 4-lug Fuchs look, and I just ...   Aug 26 2004, 09:37 PM
914Timo
  Aug 26 2004, 11:27 PM
914Timo
  Aug 26 2004, 11:38 PM
Aaron Cox   tell me about those rear sway drop links :)   Aug 27 2004, 12:04 AM
Brad Roberts   I ask the same question: Why do you *think* you n...   Aug 27 2004, 12:05 AM
Brad Roberts   Good eye (again) Aaron.. Timo tell us about your d...   Aug 27 2004, 12:08 AM
Aaron Cox   they look to be hollow and adjustable.... :idea:   Aug 27 2004, 12:13 AM
fiid   <...   Aug 27 2004, 09:52 AM
Eric_Shea   Check this thread out from last year: 911 Handbra...   Aug 27 2004, 10:07 AM
Eric_Shea
  Aug 27 2004, 10:15 AM
SirAndy     Aug 27 2004, 11:09 AM
ClayPerrine   My setup is designed to be 100% BOLT ON.. NO MACHI...   Aug 27 2004, 02:01 PM
Jeroen   Any specific years for the 911 backingplate / hand...   Aug 27 2004, 05:10 PM
Eric_Shea   Up to 73... 74 has different spacing and will not...   Aug 27 2004, 05:15 PM
Jeroen   thanks!   Aug 27 2004, 05:23 PM
- Lo-Fi Version Time is now: 1st August 2025 - 12:38 PM
