> Big Four, External oil cooler required?
saigon71
post Dec 7 2014, 09:31 AM
To the collective world knowledge database...
What is the largest size type IV that can built and used safely as a street car without adding an external oil cooler?
Thanks!
Mark Henry
post Dec 7 2014, 03:12 PM
that's what I do!
Yes and no, because I've built both with no over heat issues.
Do not use over 96mm P&C's without Nickies. Any bigger is automatically a misconfigured engine in my book.
That's a pretty basic rule, why Porsche when to an all aluminum cylinder as their engines got bigger.
Adding an oil cooler not really going to help a misconfigured engine, maybe a bit but it's a bandaid solution.
Also maybe you need one in socal, etc., but I'm taking into account the OP's location.
r_towle
post Dec 7 2014, 04:36 PM
Custom Member
QUOTE(Mark Henry @ Dec 7 2014, 04:12 PM) *
Now that LN makes nickies, it's a new possibility if you have the money.
For many years, something like 30 years, building 103mm cast iron cylinders was the norm and a typical configuration.
With cast iron cylinders, you really do need a front cooler.
With the nickies, it may help, but I have no experience with the nickies....
I do not consider using cast iron cylinders a mis configured motor or design.....it's just a cheaper way to go that has been proven to last by many builders, many motors etc.
I agree to disagree with Mark on that statement.
Rich
- Lo-Fi Version Time is now: 11th March 2026 - 03:02 PM
