> 2.0 Engine Rebuild Advice
VWTortuga336
post Nov 7 2014, 10:23 AM
I'm working on stripping down my 2.0L out of my '74. I've done a top end rebuild on my '71 Type 1 engine, but am new to Type IVs and bottom end rebuilds. So, I'm looking for some advice.
So far, from what I can tell the heads on my engine look like they are still in good, re-usable condition, but the engine is seized and the cylinders are badly rusted to the pistons. At this point, would I be better off just using the BFH method to destroy the 94mm cylinders that installed now and go with 96mm's, or is there any hope in saving these? (I'm thinking there isn't) Also, there was water in the case, so what does that typically mean for internal component replacements - cam, crank, bearings, etc? (IMG:style_emoticons/default/confused24.gif)
Just in the planning phase now and trying to collect as much info as possible.
VWTortuga336
post Nov 23 2014, 07:26 PM
I was finally able to move the crank and begin removing the pistons. I'm to the point now where I have been able to actually split the case and begin removing internals. I have a few questions:
1. I'm going to be running carbs on this engine and want to make sure I have the right cam to match. The cam that's installed looks to be in good shape, but I want to make sure it's correct. Where is the cam stamped to identify it?
2. Since there's a good chance my case is toast, due to the broken boss above the oil pickup, I'm going to attempt to reattach the broken piece, build it up, fill in the threads with JB Weld and re-tap it. I know this might not be the best, or most robust solution, but given the fact that cracking and/or breaking these on Type IV engines is very common, I'm thinking this might not be all that bad. Anyone ever tried this? Am I totally crazy for thinking this might work (IMG:style_emoticons/default/smoke.gif) ? (Pictures below)
3. The crank has lots of surface rust, but from what I can tell (very new to Type IV, untrained eyes here) seems to be in decent shape. What should I look for to determine if it's salvageable?
Bulldog9
post Dec 9 2014, 12:31 PM
It's your time and $$, but if everything else checks out (crank, con rods, P & C's I'd just go for a good used case. The only way to repair this case would be to weld a new boss then retap. My guess is you could buy a new/used case for less than this alone nevermind al lthe other work you have to do to the case. Is it really worth it? afterall the serial # is on the fan housing.
Though I am a neub, looking at your P&C's crank, con rods, bearings in the pic, I think you are looking at sourcing a 99% new motor, wil lneed to turn the crank, new P&C, rebuild con rods, and agree with others, go buy a good used motor and start from there, or have it rebuilt. If I had it to do all over again, I would have sent my longblock to McMark and called it done. Unfortunately, I diddnt find out about that option untill I was well into the project in parts and time.
I'm building mine from scratch, but my case crank, bearings and such were pristine, just dirty oil. Crank diddnt need to be turned or anything. I did buy a 2056 P&C kit, but the rest of the core components were reuseable. I have spent over $5K on my motor just in parts, and I took my time over 2 years to buy. Granted, I had to buy carbs and went to a new distributor, but it adds up, and knowing it was RIGHT is worth a ton.
Then you have to think about your heads. If they are as bad as the rest of you rmotor, they are likely unuseable. What else was cracked/damaged as you attempted this dissasembly? if you cracked that boss, I wonder what else is cracked/damaged?
It adds up......... Here is a list of my Motor build. Dont get me wrong, I am haivng fun and understand doing it yourself, but.....it's your time and $$.
ENGINE
Reinz Engine Gasket Set
Mahle Cam Bearings
Silverline Main Bearings (steel back)
Mahle Connecting Rod Bearings
Reinze Oil filter & sump seal
96MM 2.0 PISTON & PIN - Keith Black (EMW)
96MM Cast Iron CYL - (EMW)
96MM RING SET 1.8, 2.0 K/B - Hastings
.060 CYL SHIMS
Remanufacture Heads (Hoffman)
Modified 1.7 Rocker Arms (Hoffman Modified)
Mahle-Wizemann 911 Swivel Foot Adjusters & Nuts
26MM FLAT OIL PUMP & cover
MOCAL OILSTAT SANDWICH ADAPTER with thermostat
WEBCAM EMW G CAM 287 DUR. X .430" LIFT
WEBCAM ALUMINUM CAM GEAR & Bolts
SOLID LIFTER - Scat Performance Lubealobe
CHROMOLY CUT TO FIT PUSHRODS 3/8
Oil Strainer & gasket
Viton pushrod tube seals (16)
Alternator 75Amp remanufactured Bosch
Alternator - Fanbelt
Bosch starter relay/hot start kit
Starter - Bosch Remanufactured
Spark Plug Tin Boots - OEM
Valve Covers - Aluminum Ribbed (CB Performance)
Thermostat & Cable - (Awesome powdercoat)
Sport Engine Mounts (rear/transmission) OEM
Engine Mounts (Front) - OEM
Pertronix BILLET DIST. W/IGNITOR 2
Pertronix FLAME-THROWER COIL 3.0 OHM
Pertronix WIRE SET BLK 35.00 35.00
Dellorto 36DLRA Carbs & Mounts & Jets
Air Filter Gasket, Pair
Dellorto DRLA "Anti-Whistle" Base Gasket,
SCAT Centerpull Linkage
Oil Pressure Sending Unit, Stock, 021-919-081B
VDO 80psi Oil Pressure Sending Unit, 1/8 -27 NPTF
VDO Sending Unit "T" Adapter, 1/8 - 27, V240850
12mm Nut (8mm Thread), 12 Pieces
ACN Flanged Racing Intake/Exhaust Nuts, 8 x 10m
New Cam Plug
Raby Engine nuts & bolt kit
New Tin Screws
New Con Rod Nuts
New Rocker Arm Nuts
Curil-T Engine Sealant, 75ml Tube
Curil-K2 Engine Sealant, 125ml Bottle with Brush
Machining: Case cleaned and boresited, crank mic'd polished and rotating mass balanced.
QUOTE(VWTortuga336 @ Nov 23 2014, 08:26 PM) *
VWTortuga336   2.0 Engine Rebuild Advice   Nov 7 2014, 10:23 AM
eyesright   My 2.0 was a '76 with lower compression dished...   Nov 7 2014, 11:07 AM
VWTortuga336   I'm planning on doing as much of the work myse...   Nov 7 2014, 11:18 AM
barefoot   I'm going thru the same thing presently and pl...   Nov 7 2014, 11:29 AM
mapguy   I am also going through this right now. I decided...   Nov 7 2014, 12:51 PM
DavidSweden   What components do you have to change when changin...   Nov 7 2014, 01:08 PM
VWTortuga336   Someone please correct me if I'm wrong, but it...   Nov 7 2014, 01:12 PM
pilothyer   Someone please correct me if I'm wrong, but i...   Nov 7 2014, 01:41 PM
Bob L.   You can get the 96mm pistons and if your cylinders...   Nov 7 2014, 01:41 PM
mapguy   Correct, the 96mm P/C fit with no modification. If...   Nov 7 2014, 02:39 PM
VWTortuga336   Well, I am just about to the point where I'm t...   Nov 11 2014, 12:37 PM
stugray   You should be able to get the pistons out without ...   Nov 11 2014, 01:13 PM
VWTortuga336   Stupid question time: what do I need to look for o...   Nov 11 2014, 02:40 PM
r_towle   If you cannot move it, put it on a stand, tip it s...   Nov 11 2014, 03:53 PM
VWTortuga336   Here's a pic of one of the cylinders, showing ...   Nov 11 2014, 09:47 PM
VWTortuga336   Anyone have any opinions on these fins? Also, is ...   Nov 14 2014, 09:02 AM
pilothyer   Anyone have any opinions on these fins? Also, is...   Nov 14 2014, 02:42 PM
Steve Pratel   I kept my original P&C's, & have them...   Nov 14 2014, 04:11 PM
VWTortuga336   I took everyone's advice and decided to go wit...   Nov 14 2014, 06:20 PM
stugray   You can either remove the rods from the crank, or ...   Nov 14 2014, 09:17 PM
r_towle   Remove rods from crank. Bolt the case to a long b...   Nov 14 2014, 09:48 PM
VWTortuga336   I just hit another snag...when I was removing the ...   Nov 15 2014, 08:31 AM
Dave_Darling   ...I forgot about the bolt that goes above the sum...   Nov 15 2014, 11:49 AM
Jesco Reient   I just hit another snag...when I was removing the...   Nov 15 2014, 12:40 PM
veekry9   Yes,a submerged engine needs a delicate approach,l...   Nov 15 2014, 08:52 AM
Java2570   I'd give Brad Mayeur a call: http://914ltd.com...   Nov 15 2014, 11:56 AM
stugray   No Problem. If you had waited 45 more minutes I ...   Nov 15 2014, 01:32 PM
Old Yella   Hi I don't normally comment but thought I woul...   Nov 15 2014, 03:16 PM
DavidSweden   Yes you can pay someone to do it for you. But isn...   Nov 15 2014, 03:26 PM
Highland   I agree with David. What's the point if you d...   Nov 15 2014, 05:03 PM
Old Yella   The reason I usually don't comment is the endl...   Nov 15 2014, 06:05 PM
DavidSweden   The reason I usually don't comment is the end...   Nov 15 2014, 06:18 PM
914_teener   The reason I usually don't comment is the en...   Dec 8 2014, 01:54 PM
VWTortuga336   I gotta say, I do enjoy working on my cars as much...   Nov 15 2014, 06:38 PM
DirtyCossack   Marvel Mystery Oil can break the pistons free with...   Nov 16 2014, 02:47 PM
VWTortuga336   I was finally able to move the crank and begin rem...   Nov 23 2014, 07:26 PM
Steve Pratel   It's your time and $$, but if everyt...   Dec 9 2014, 12:31 PM
VWTortuga336   Just another thought, would it be possible to do t...   Nov 23 2014, 08:42 PM
mapguy   I really like this thread, it makes me thankful of...   Nov 24 2014, 12:53 PM
funk   European motor works has cases at reasonable price...   Dec 8 2014, 12:40 AM
- Lo-Fi Version Time is now: 7th March 2026 - 12:44 AM
