McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Hey guys, check my logic here. I see this type of grooving all the time, on nearly every pressure plate I see - regardless of engine type, horsepower, etc. I hadn't given it too much thought other than, "I don't like it, but it happens every time." But I was just talking with someone and it occurred to me that this might be wear caused by a bad throwout bearing. If the grease is sticky, or if dirt has infiltrated the bearing, it may not be able to rotate/spin correctly and would slip causing wear.
The point of the throwout bearing should be to stop exactly this type of wear, right? Doest this mean bad throwout bearings are super common? Or is this a symptom of a loose clutch cable, not holding the throwout bearing tight to the fingers and that lets them slip? Attached thumbnail(s) ![]() |
wndsnd |
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States ![]() ![]() |
I have learned this as well. Always go into neutral, never hold the clutch down at a stop. Probably easier on the clutch cable tube as well. But wouldn't a properly adjusted clutch just narrowly disengage the throwout bearing in neutral. So when the clutch is depressed every time, the bearing has to make contact with those fingers which are rotating and the bearing is not. Friction would occur at every gear change.
John |
Lo-Fi Version | Time is now: 22nd September 2025 - 07:33 PM |
