2258 4cyl engine- nice parts, almost plug n play, Engine, Carbs, Headers, Exhaust... |
tornik550 |
Dec 7 2014, 05:57 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I had not planned on getting rid of this engine however I saw a 6 cyl posted in the classified section and figured it would be fun to change directions. I rebuild this engine in 2011/2012. I have put about 1-2000 miles on it since then. The engine runs well and puts a smile on your face when the carbs are tuned. Over the passed year I had been having issues with the mixture always being rich. I had tried many different remedies and nothing worked. In October 2014 I realize that my fuel pressure gauge was stuck and three psi. I thought the fuel pressure was appropriate however when I purchased a new gauge I found that the pressure was at almost 6psi. I have fixed that problem by purchasing a new regulator however I have not had time to retune the engine using the correct fuel pressure (fuel gauge and regulator not included in sale).
Problems -a few oil leaks here and there. For the most part they never bothered me so I never tried to fix them. The drivers side valve cover seems to leak a little. No a huge amount however when it does it drips right onto a header pipe. I drove me nuts and I wasn't able to fix the issue so I just built a little shield to deflect the oil away from the pipe. -cooling fan has one broken fin (from everything I see, one broken fin is not an issue) -I currently do not have the carbs setup the correct jetting (haven't had time to fix). Somebody better than me needs to tune them. Positives -nice setup, fun to drive, many expensive parts -I always had very good oil pressure -oil temps always good however I do have an external oil cooler (not included) -Almost plug n play Items needed to run engine in a 914 -a 914 (IMG:style_emoticons/default/biggrin.gif) -ENGINE TIN (2.0l style) -Oil pressure sender -oil (IMG:style_emoticons/default/biggrin.gif) -Spark plugs -ignition coil -I cannot think of anything else it needs however there may be something small here or there but i don't think so. Other than the stuff mentioned above, it should be plug n play assuming that you have a 914 with the normal relay board, wiring harness... Disclaimer- I built this engine for myself. I tried to do a very precise job. I feel that I did a decent job building the engine however I am absolutely not a professional. The engine was running fine with the exception of the fuel mixture issues. I feel this can be worked out by someone who can tune carbs. I simply haven't had time to play with them since I found my fuel pressure issue- all of that being said- I am no expert. Bottom line- I feel good about the engine however even if you do not like my engine building abilities- the parts alone are worth way more than the sale price. 2258 78mm counterweighted crankshaft 9.5:1 compression ratio 5.3" con rods Arp rod bolts Scat c45 camshaft Double thrust camshaft bearings Chromoly pushrods 911 style valve adjusters Universal vw case- was nos at rebuild- galleys tapped and plugged KB 96mm pistons with valve pockets Hastings rings European motorworks 96mm cylinder jugs (new at rebuild) New at rebuild AMC cylinder heads (porsche 2.0 configuration) with 12mm spark plug holes, 44intake/38exhaust valves, CNC ported, dual valve springs. Dual Weber IDF carbs (1year old) ITG foam carb filters Tunacan oil sump Mallory adjustable distributor Clewett spark plug wires CSP bellcrank carb linkage Triad headers (1 5/8" pipes) Triad dual tip exhaust 75amp alternator Includes flywheel, cluch pressure plate 30mm Schadek oil pump Asking price $3000 obo. Will ship within the continental US at your expense- or of coarse local pick up. Attached image(s) |
tornik550 |
Dec 9 2014, 02:17 PM
Price change-
Now asking $3000 |
Lo-Fi Version | Time is now: 7th June 2024 - 09:26 PM |
