McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Hey guys, check my logic here. I see this type of grooving all the time, on nearly every pressure plate I see - regardless of engine type, horsepower, etc. I hadn't given it too much thought other than, "I don't like it, but it happens every time." But I was just talking with someone and it occurred to me that this might be wear caused by a bad throwout bearing. If the grease is sticky, or if dirt has infiltrated the bearing, it may not be able to rotate/spin correctly and would slip causing wear.
The point of the throwout bearing should be to stop exactly this type of wear, right? Doest this mean bad throwout bearings are super common? Or is this a symptom of a loose clutch cable, not holding the throwout bearing tight to the fingers and that lets them slip? Attached thumbnail(s) ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Got it....
Again, it's a risk, but if it's free or super cheap, and you are ok replacing it eventually, go for it....but know it's an issue that will need to be fixed...soon. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,318 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
if it's free or super cheap I have yet to receive the beer i asked for it ... (IMG:style_emoticons/default/biggrin.gif) |
JStroud |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California ![]() |
if it's free or super cheap I have yet to receive the beer i asked for it ... (IMG:style_emoticons/default/biggrin.gif) That's only because I haven't seen you yet!! (IMG:style_emoticons/default/beerchug.gif) Come by the shop.....all the beer you can (IMG:style_emoticons/default/beer3.gif) |
Lo-Fi Version | Time is now: 22nd September 2025 - 07:32 PM |
