> Pressure Plate Finger Grooves, caused by the throwout bearing
McMark
post Dec 9 2014, 11:25 AM
914 Freak!
Hey guys, check my logic here. I see this type of grooving all the time, on nearly every pressure plate I see - regardless of engine type, horsepower, etc. I hadn't given it too much thought other than, "I don't like it, but it happens every time." But I was just talking with someone and it occurred to me that this might be wear caused by a bad throwout bearing. If the grease is sticky, or if dirt has infiltrated the bearing, it may not be able to rotate/spin correctly and would slip causing wear.
The point of the throwout bearing should be to stop exactly this type of wear, right?
Doest this mean bad throwout bearings are super common?
Or is this a symptom of a loose clutch cable, not holding the throwout bearing tight to the fingers and that lets them slip?
aircooledboy
post Dec 9 2014, 11:40 AM
Sweet Pea's 1st ride in daddy's "vroom -vroom"
QUOTE(McMark @ Dec 9 2014, 11:25 AM) *
I always understood this was the opposite of a loose cable. I thought ideally your throw out should hover just out of contact with the pressure plate fingers to avoid premature wear to both the bearing and the pressure plate springs, but since many cars have their clutch cable too tight, you get this. (IMG:style_emoticons/default/confused24.gif)
Dave_Darling
post Dec 9 2014, 07:45 PM
914 Idiot
QUOTE(aircooledboy @ Dec 9 2014, 09:40 AM) *
I thought ideally your throw out should hover just out of contact with the pressure plate fingers ...
Not on a 914, at the very least! Remember, the 914 has a spring on the pedal cluster that pulls the pedal down in the "press the pedal" direction. That means there is always pressure on the throwout bearing--though not a lot.
This kind of wear is exceedingly common--maybe universal? I don't know why, because it seems to me that the T/O bearing should be there to prevent that. Especially if the bearing is always in contact with the fingers on the plate, so it should not have a chance to slip.
Maybe it would be worse without a real bearing in place?
Do you have photos of the throwout bearing?
What does the bearing surface look like?
The top of the bearing has a rounded surface. Basically it's just the inverse of the wear that you see in the pressure plate fingers in the pics above.
Here's a pic:
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.pelicanparts.com-121-1418175958.1.jpg)
--DD
DBCooper
post Dec 10 2014, 09:39 AM
14's in the 13's with ATTITUDE
QUOTE(Dave_Darling @ Dec 9 2014, 05:45 PM) *
I don't think so. There's also a much larger spring on the transmission's clutch arm that pulls it back, disengaging. You need free play at the top of your clutch pedal, meaning no contact between the release bearing and the pressure plate until you press the pedal past the free play. I think those grooves are created from the friction of the "spin up" of the stationary release bearing as it matches speed after contacting the spinning pressure plate. When the grooves are deep that metal's gone and not coming back, so it's time for a new pressure plate.
When you sit at a stop light with the clutch disengaged you're wearing the throw out bearing, but much worse is that you're causing unneeded wear on the engine's thrust bearing. It's what limits the front-back movement of the crankshaft, and every time you press the clutch the pressure opens the pressure plate, but it also presses the flywheel and crankshaft forward, against the thrust bearing. And it's a heck of a lot more expensive to replace a main bearing set than a throw out bearing. You check how many miles are on the bug's T1 engine by pulling and pushing the crank pulley? Any movement is end-play from a worn thrust bearing, meaning a lot of miles on the engine (or a lot of time at stoplights with the clutch in) and an impending engine rebuild.
Dave_Darling
post Dec 10 2014, 11:06 AM
914 Idiot
QUOTE(DBCooper @ Dec 10 2014, 07:39 AM) *
What transmission do you have? Because you're not describing a 901-based 914 transmission here--there is no spring on the throwout arm at all. Maybe the 915 version out of the mid-year 911s...
--DD
McMark   Pressure Plate Finger Grooves   Dec 9 2014, 11:25 AM
altitude411   How many miles are on that PP? What type of drivin...   Dec 9 2014, 11:31 AM
aircooledboy   The point of the throwout bearing should be to s...   Dec 9 2014, 11:40 AM
Dave_Darling   I thought ideally your throw out should hover just...   Dec 9 2014, 07:45 PM
scruz914   ..... there is always pressure on the throwout be...   Dec 9 2014, 08:23 PM
DBCooper   I thought ideally your throw out should hover jus...   Dec 10 2014, 09:39 AM
Dave_Darling   I don't think so. There's also a much la...   Dec 10 2014, 11:06 AM
Bartlett 914   Hey guys, check my logic here. I see this type o...   Dec 9 2014, 12:12 PM
roblav1   Looks like a real lot shifting, a too tight cable,...   Dec 9 2014, 12:19 PM
Valy   It happens to all pressure plates, regardless of c...   Dec 9 2014, 12:23 PM
Elliot Cannon   This is one reason I have been taught in the past ...   Dec 9 2014, 12:41 PM
r_towle   This is one reason I have been taught in the past...   Dec 9 2014, 07:34 PM
wndsnd   I have learned this as well. Always go into neutr...   Dec 9 2014, 01:13 PM
McMark   356 Pressure Plate of unknown age. 914 Pressure ...   Dec 9 2014, 01:21 PM
scruz914   Do you have photos of the throwout bearing? What d...   Dec 9 2014, 01:34 PM
JStroud   So my question, the PP picture in the first post, ...   Dec 9 2014, 08:29 PM
SirAndy   I ask because I'm the one that sent it to McMa...   Dec 9 2014, 08:51 PM
Cap'n Krusty   I ask because I'm the one that sent it to McM...   Dec 9 2014, 09:06 PM
r_towle   I ask because I'm the one that sent it to McM...   Dec 9 2014, 09:50 PM
SirAndy   From what I could tell once it started to get loud...   Dec 9 2014, 09:56 PM
tdgray   I just changed my fifty plus year old original pre...   Dec 9 2014, 08:43 PM
larryM   here is a good start for further investigation: se...   Dec 9 2014, 08:50 PM
r_towle   Got it.... Again, it's a risk, but if it's...   Dec 9 2014, 10:00 PM
SirAndy   if it's free or super cheap I have yet to rec...   Dec 9 2014, 10:03 PM
JStroud   if it's free or super cheap I have yet to re...   Dec 9 2014, 10:10 PM
JStroud   Got it.... Again, it's a risk, but if it...   Dec 10 2014, 09:16 AM
McMark   Got it.... Again, it's a risk, but if it...   Dec 10 2014, 06:21 PM
r_towle   [quote name='JStroud' post='2120733' date='Dec 10...   Dec 10 2014, 07:01 PM
JStroud   [quote name='JStroud' post='2120733' date='Dec 1...   Dec 11 2014, 12:36 AM
DBCooper   Ahhchh.... you're right, Dave, that spring is ...   Dec 10 2014, 03:30 PM
a few loose screws   Wow, What a dumb design. glad i read this. Another...   Dec 10 2014, 05:56 PM
DBCooper   Wow, What a dumb design. glad i read this. Anothe...   Dec 10 2014, 06:23 PM
DBCooper   Fingers broke on my son's Kennedy pressure pla...   Dec 10 2014, 06:32 PM
Bartlett 914   A lot of the comments seem to point to the throwou...   Dec 10 2014, 06:32 PM
a few loose screws   I was referring to the clutch release bearing havi...   Dec 10 2014, 06:44 PM
edwin   Most clutches that I've replaced have looked l...   Dec 11 2014, 01:57 AM
- Lo-Fi Version Time is now: 22nd September 2025 - 07:35 PM
