| mbseto |
Dec 10 2014, 04:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,257 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
I suppose air tools are as much 914-related as jackstands are... And although these days it seems they are considered disposable, this one has grown on me and a rebuild kit is available so I did the work. Maybe someone out there may benefit from the photos.
It's a 3HP motor, which is within a 1/2HP of my push mower. EDIT: Guess I should mention, it's an ATSCO 1700. |
| mbseto |
Dec 10 2014, 05:10 PM
The motor endcaps/bearing cups are line-to-line fit with a key. Once the regulator is out of the way, they can be pushed out with the shaft.
Here's one end off, showing the rotor: And the other end popped out with the shaft attached. If everything is clean, the vanes will just fall out. Vanes are a replacement item: The cap and the bearing cup on this end are separate pieces. There's the shaft key for the rotor lying there and the other gasket to be replaced: |
mbseto Large Marge - air tool rebuild. Dec 10 2014, 04:48 PM
mbseto Removed the guard:
Removed the end cover:
Remo... Dec 10 2014, 04:52 PM
mbseto Took a break, refreshed my cardboard...
Put the e... Dec 10 2014, 04:59 PM
02loftsmoor I used those before, Man killer Dec 10 2014, 05:18 PM
mbseto This shaft assy was a bit of a puzzle. Decided to... Dec 10 2014, 05:20 PM
mbseto Soaked everything in light oil, deglazed the pan w... Dec 10 2014, 05:23 PM
mbseto
https://www.fli... Dec 10 2014, 05:27 PM
ThePaintedMan Now THAT'S cool! :trophy: Dec 10 2014, 05:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 09:45 AM |
