> Large Marge - air tool rebuild., In which an air tool is rebuilt.
mbseto
post Dec 10 2014, 04:48 PM
I suppose air tools are as much 914-related as jackstands are... And although these days it seems they are considered disposable, this one has grown on me and a rebuild kit is available so I did the work. Maybe someone out there may benefit from the photos.
It's a 3HP motor, which is within a 1/2HP of my push mower.
EDIT: Guess I should mention, it's an ATSCO 1700.
mbseto
post Dec 10 2014, 05:20 PM
This shaft assy was a bit of a puzzle. Decided to ask a guy at the maintenance place before I got too far up the "bigger hammer" ladder. He said, put the shaft ket back in the slot and slide the rotor back on the shaft. Wrap the rotor in a piece of leather or similar and clamp gently in a vise. Then spin the end plate off using the flats:
If the bearing needs to be replaced, it is pressed in to the plate with the bolt holes, and trapped by the adjacent plate, which is screwed on with left-hand threads. That adjacent plate has no flats, there is just a hole in the side of it, I assume to take a spanner-like tool if you do not want to use a more galoot-like method of removal.
- Lo-Fi Version Time is now: 14th April 2026 - 09:45 AM
